2013 v6 auto select shift issue
Hi guys. Do any of you have an issue with selectshift like this: once in selectshift mode, when you go to change a gear(especially shifting up, but does it on both), does the car not respond?
On mine sometimes I gotta press it many times, and it still won't work. So I try pressing into it at a different angle. Sometimes that works. And other times it just won't work, and I have no choice but to put it back into drive mode to get the gears to change. Selectshift is soooo in consistent, I'm afraid to use it.
Anybody else run into this? Could be the button is simply loose or something? Please chime in, any help is appreciated.
PS. Plan to pay a visit to the dealership soon... But I dread the dealerships
I had that problem on my 2014. It would downshift just fine but it got to the point where I had to press the upshift button just right. My dealer replaced the SelectShift button under warranty and no problems since.
I recommend you bring it in to your Ford Dealer first and have this shifting concern diagnosed. Make sure you speak with your service manager if needed. He is in the best position to ensure a proper diagnosis, and will be able to provide available options and/or coverage for any work needed.
You can schedule an appointment online here. Let me know the outcome.
Deysha
Hi roadrunner,
Deysha
Deysha
ssjbuu
8/28/15 08:55 AM
