2013 mustang gt rear end noise
Have 66k miles
Just bought car, this noise only happens when you first turn on after sitting for a while.
Someone told me it may be the wrong axle fluid used when fixing one of the seals.
What's is this noise?
Does it happen after you've been driving for a bit and only when you turn? I had something similar on my 2000 and it was the clutch packs.
I don't really know; but it could be that they left out the limited slip friction modifier when they changed the diff fluid. You could try adding a tube of it; then do a few tight figure-eights in a parking lot to work it in to the clutch packs. If that makes it go away, then that was it. . . if it doesn't, then it wasn't.
Do you always use the parking brake?
If so, try leaving it off next time and see if the noise is still there.
If not, then it's got something to do with the brakes.
Did you recently have rear brake service done?
Could simply be cheap pads sticking to the rotors
tmarko
Jun 6, 2016 12:47 PM
