2013 Mustang Daytime running lights out on passenger side.
Old Sep 10, 2017 | 05:09 PM
Tylen Oubre's Avatar
Is there a bulb I have to change or are they led's?
Old Sep 10, 2017 | 05:31 PM
SpectreH's Avatar
I believe they are LEDs.
Old Sep 10, 2017 | 06:40 PM
So would I have to change the led strips or the whole headlight component?
Old Sep 10, 2017 | 08:29 PM
SpectreH's Avatar
You have to use a heat gun to open up the headlight assembly to replace the strips or replace the whole thing. Have you verified the connector/wiring are good? Proper voltage making it to the headlight assembly?
Old Sep 10, 2017 | 11:19 PM
I'll check it in the morning. I replaced my battery with a new battery two days ago also. Do you think that has something to do with it?
Old Sep 11, 2017 | 09:51 AM
SpectreH's Avatar
I don't see how, but stranger things have happened. You could try disconnecting your battery, wait 5 minutes or so, then reconnect.
Old Sep 11, 2017 | 03:58 PM
Yeah when I get home I'm gonna check the fuse box. I'm thinking maybe it's a blown fuse.
Old May 23, 2020 | 09:49 PM
Landen208's Avatar
I know its been a hot minute since this thread has had any activity but I just had the same exact issue come up. Was working on my car and my battery was low so I had to charge it. Start it up then the passenger side DRL's stopped working too. What did you end up doing to fix it?
Old May 31, 2020 | 11:32 AM
JonsMustang's Avatar
You tried restarting the car battery?
Old Jun 1, 2020 | 08:34 AM
Landen208's Avatar
Im sure you meant reconnecting the battery....yes yes I have about 5 times trying to diagnose this issue. I have no fault codes from the computer in ForScan and no relay or fuses are out. Talked to a Ford dealer and the LED board doesn't exist apparently. Currently in talks with ford themselves because a wiring diagram doesn't exist for the DRL's even tho it's a replaceable board with a harness connecting to it with a removable connector. Service tech himself doesn't know anything either. Nonetheless I've tried. Only a few people have reported the passenger side failing and I want to hear from those people if that's understandable because I have done my troubleshooting lmao
Old Nov 30, 2020 | 05:23 PM
giovannyram's Avatar
Same problem
Did you fix it? I have the same problem and I don't know what to do :/
Old Nov 30, 2020 | 06:29 PM
Landen208's Avatar
Bad news sadly I couldn't track literally anything down, Ford was no help either. No schematics internally at all other than one that didn't help me. I just went with the Diode dynamics replacement. Technically the cheapest option
