2013 GT and downshifting
Old Oct 18, 2012 | 08:30 PM
Xtian85's Avatar
Am I the only one having a hard time downshifting smoothly? The car just dives so much when going down a gear. I've even been trying to rev match on the downshift to make things smoother, but it's hardly successful. I used to own an 07 GSXR 750 and a 5 speed car with an 8lb flywheel and got used to rev matching, but I'm not getting it with this car. How are you guys doing? How heavy is the flywheel on this car it revs like it's 50lbs.
Old Oct 18, 2012 | 09:09 PM
kylerohde's Avatar
If you're not rev-matching, it's going to be really rough, of course. And a Mustang is completely different than a bike...it just takes practice.
Old Oct 18, 2012 | 10:44 PM
Mirad_GT12's Avatar
Different car, different gear and rpms that you have to match on the blip.
Old Oct 19, 2012 | 05:17 AM
MRGTX's Avatar
+1
These cars can be downshifted smoothly and you'll get it with practice... you already understand the concept so you're farther along than many folks on this forum.
Old Oct 19, 2012 | 05:20 AM
GRN 5OH's Avatar
Practice some more? Rev that MF up bro!
2012BLKV6's Avatar
Yup. I don't downshift ever without rev-matching in this car. Are you double clutch or single clutch downshifting?
Old Oct 19, 2012 | 07:45 AM
jonny88's Avatar
I know what you mean about the flywheels. I had a subaru with a 12lb flywheel and just a small blip is all it took to rev match. This thing feels like I have to try to hit redline every time to get it to match up. I usually heel toe so it's a little more intrusive to hold the throttle that long while on the brake and all the other things I'm trying to do simultaneously.
Old Oct 19, 2012 | 09:32 AM
wheelman's Avatar
Took me a little while to get it right too, even coming from another Mustang, but its so much easier w/ a 6 speed. No more heavy engine braking. I blip it like 500-1k RPMs and try to skip gears when I can, but it depends on your speed. And if Im early on the blip, like on a turn, I hit it again. Still fine tuning it all, but Ive got her running smooth now. Youll get it.
P.S. When in doubt, use your brake and save your clutch.
Old Oct 19, 2012 | 10:17 AM
youngstang90's Avatar
And be easy releasing the clutch. A lot of the 'smoothness' is found here.
Old Oct 19, 2012 | 10:25 AM
2012BLKV6's Avatar
also a lot of the clutch/syncro wear is found there. The point of rev matching is so you don't have to be slow on the clutch and can therefore quicker
Old Oct 19, 2012 | 10:31 AM
Stevedotmil's Avatar
Took me about 2K miles to really get used to the blip on this car. A lot more fun now that I've got it though. Smoother as well. Practice practice practice.
Old Oct 20, 2012 | 01:10 PM
conv_stang's Avatar
most of its because of the lag in the electronic throttle...just takes a little while b/c it doesnt rev as quick as a bike or a car with a cable throttle
Old Oct 21, 2012 | 04:39 PM
2012BLKV6's Avatar
Is it true that a tune removes some of the rev hang?
Old Oct 22, 2012 | 08:50 AM
mfc133's Avatar
Yeah like most late model manual trans cars it has a heavy flywheel and the electronic throttle lag that makes it tricky to time it. But, for me at least, I think the pedal placement in this car makes the blip much easier.
Old Oct 27, 2012 | 06:23 PM
conv_stang's Avatar
yes, all the tuned cars ive driven the throttle response is much better. Still not as easy as in my 98 Cobra. But that has a lightweight clutch, driveshaft and flywheel. So it revs to the moon easily
Old Oct 29, 2012 | 12:15 AM
me32's Avatar
It's not that bad. Just work on it.
Old Oct 29, 2012 | 08:44 AM
kylerohde's Avatar
Personally, I don't feel any kind of lag. If I didn't know better, I'd think it was a cable throttle. Electronic throttles have come a long way quickly, in comparing my Stang to my previous car ('03 Mazda6). The throttle on our cars is precise enough that I find it easy to move in bumper-to-bumper traffic at 1,000 RPM or less. It'd be hard to do that with a bad lag.
Old Oct 29, 2012 | 09:04 AM
u00mem9's Avatar
He is talking about heel-toe. A big part of the issue is the brake override setting that prevents Toyota style failure. If you totally defeat the advance track (long press with brake) you will allow simultaneous application of brake and throttle. Only Mustang and raptor have a way to turn that off.
Old Oct 29, 2012 | 03:40 PM
kylerohde's Avatar
Not true on my car. I heel-toe constantly and never have any kind of issue, and I'm not turning off any of the safety nets to do it.
Rando
Aug 25, 2021 11:12 AM
UOP Shadow
Sep 27, 2015 07:24 AM
Sep 23, 2015 03:21 PM
DarrenGT
Sep 19, 2015 01:00 PM
