2011 GT Powertrain Uses TI-VCT to Make 400+ HP, Deliver Unsurpassed Fuel Economy
Old Dec 28, 2009 | 03:59 PM
eci's Avatar
eci
Skipshift can be tuned out at least.
Old Dec 28, 2009 | 04:01 PM
3Mach1's Avatar
Originally Posted by Boomer
it also has skip shift..
The Mustang has the skipt shift?? Out of curiousity will the ls3 run on 87? Somebody reported the other day a bad knock while running it.
Old Dec 28, 2009 | 04:02 PM
Boomer's Avatar
It would be nice if it was a tag that could be changed in a handheld... OR.... have a manual overide button (like traction control)
Old Dec 28, 2009 | 04:57 PM
EagleStroker's Avatar
I don't do trannies
or rear-ends anymore!
That crank looks awfully similar to the forged one that we offer for the 4.6, and also looks like a variant on the 4.6 design itself. I'll just wait until they release short block details
Old Dec 28, 2009 | 07:13 PM
Tony Alonso's Avatar
Originally Posted by Tony Alonso
The way I read the article, you need to use premium for the 412hp, otherwise, if you use regular, you get a little less.
According to this Car and Driver article, "regular unleaded is acceptable to use, but expect the power ceiling to drop by 10 ponies and 13 lb-ft should you choose the cheap stuff."
Old Dec 30, 2009 | 10:52 PM
TXBLUOVAL's Avatar
Cool
Nice horsepower with variable fuel - good.
Skip-shift - nope
"Composite" (plastic) intake manifold - never
Current body design - MUST CHANGE
Bottom line; Power sounds impressive but I won't be buying one with any 1 or more of the issues above.
Old Dec 30, 2009 | 11:04 PM
Five Oh Brian's Avatar
I remember speaking with Art Hyde about 9 years ago when he was the Mustang Chief Engineer. I asked him about CAFE ratings, bigger motors, steeper gears, etc. for future Mustangs and how GM had skip shift to help mileage. He assured me that there was no way that the EPA would ever allow skip shift again as a way to bolster MPG on paper and that GM was only able to offer it as they were grandfathered into it since the EPA banned it after GM started using it. Basically, the EPA knew it was a sham since it only worked a very light throttle and lower speeds. Give it moderate throttle or shift at higher speeds and it was bypassed. Plus, aftermarket tuning was very simple to defeat it, so the EPA supposedly said "never again."
So, I'm VERY surpised to hear there's been a change in policy on the subject.
Old Dec 30, 2009 | 11:22 PM
Captain Spadaro's Avatar
The GM spec sheet says "premium recommended but not required" (or something to that effect).
Old Dec 30, 2009 | 11:23 PM
eci's Avatar
eci
Modern LS ECM's have an adaptive fuel strategy and knock sensors. You can run whatever fuel you like.
Old Dec 31, 2009 | 12:09 AM
Fazm's Avatar
Skip-shift - nope
fine by us
Old Dec 31, 2009 | 01:39 AM
stangfoeva's Avatar
MOTM Committee Member
Originally Posted by Fazm
fine by us
exactly if the '11 GT doesn't satisfy him only a GT500 will
Old Dec 31, 2009 | 02:58 AM
3Mach1's Avatar
Boomer, I did not undrstand you. Does the new 2011 Mustang have the skip ship option?
Its not a big deal and easily defeated but I wanted to know. Thank you.
Old Dec 31, 2009 | 03:01 AM
3Mach1's Avatar
Thank you a ton Brian for this informnation. I appreciate it very much. Thank you.
Old Dec 31, 2009 | 01:50 PM
94gt's Avatar
For 4,951cc that is impressive HP to say the least at 83.2 hp per liter compared to the camaro at 69.1 hp per liter with there 6.2L V-8. That being said I was hoping for better mileage than the Camaro especially considering the cars considerably bigger engine and added weight. I wouldn't have thought with the 275 lb. weight loss between the Camaro and Mustang and the smaller engine with less hp getting 25 mpg from the manual or 26 mpg from the auto would have been that hard.
Old Dec 31, 2009 | 01:52 PM
94gt's Avatar
Skip-shift - nope
For this supposedly modern design it looks an awful lot like the 69-70 mustang with 67-68 cues thrown in for good measure. You must not like the 69-70 mustang then.
Old Dec 31, 2009 | 05:42 PM
TXBLUOVAL's Avatar
I owned a 69 S-code Mach 1. That is my favorite year.
No, IMO it looks nothing like a 69-70 at all, especially with it's Camaro hood.
Old Dec 31, 2009 | 05:53 PM
jedikd's Avatar
Skip-shift - nope
Hahaha, i love when people post complaints about a car with a "Ransom" list of things that must be fixed before they'll buy the car... i'm sure Ford will get right on it!
Old Dec 31, 2009 | 06:58 PM
Ice Hawk's Avatar
Call me ignorant, because I am, but what is "Skip Shift"? Sounds like it jumps two gears instead of one on slow accelerations? That's just out of context in this post. I really have no idea.
Old Dec 31, 2009 | 07:00 PM
eci's Avatar
eci
Solenoid in the trans that blocks the shift linkage from engaging 2nd and makes it glide right into forth. Computer controlled.
Old Dec 31, 2009 | 08:51 PM
  #40
94gt's Avatar
WOW, okay the hood is more 84gt, but the rest of the car is scary similiar to the 69-70. Look at the side profile, it is **** near identical with the exception of the the wraparound taillights again very similiar to the Camaro.
