2011+ GT headlight connector pinout ?
Hey all, looking for the pinout of a 2011-2014 GT headlight connector for the SW6659 headlight switch. Example below of the 2005-2009 pinout. Are they the same? if so how does the automatic headlight position work?
I do not have the switch but according to the workshop manual it is pin 4 and the rest of the pins look like they might have changed a little also
yeah, ****. I've seen that diagram but I don't think its enough for me. I'm trying to create an 'adapter' harness. I've pulled from junk yards a couple of similar switches in that they use the same 10 pin connector. One was from a 2012 mustang with no fogs or auto headlamp, the other from an explorer. The harness on each is using 9 out of the 10 pins The explorer switch has all 10 pins and the mustang switch is missing pins 4,5,9 and 10. One harness is missing a wire in the 9 slot, the other in the 2. I think the mustang harness is missing the e9 pin but I may have mixed them up over time.
