2011 Brembo Package ? ? ? What all included
Old Feb 4, 2010 | 02:56 PM
coolmac's Avatar
What does the Brembo package include?
I know 14" Brembo front brakes and 19" wheels w/summer tires.
Different springs, sway bars, struts and shocks ? ? ?
I also read the Brembo calipers can not be rebuilt.
The dealer was no help . . .
Old Feb 4, 2010 | 03:27 PM
06GT's Avatar
Can get rebuild components (Dust boots, pressure seals) from Zeckhausen Racing http://www.zeckhausen.com/. It is the Brembo F50 caliper, judging from what I saw in pics and at Barrett Jackson.
Old Feb 4, 2010 | 04:00 PM
whysoserious's Avatar
As I understand it the suspension components are the same as on the non-Brembo GTs, however the ESC has been recalibrated, much like the track pack from 2010. Someone correct me if I am mis-informed.
Old Feb 4, 2010 | 04:01 PM
1969 Boss429's Avatar
I would like to know as well. I am interested to know what all is included in the Brembo package as I am not crazy about the wheels that come with it. Can they be swapped out with any of the other wheels offered?
Old Feb 4, 2010 | 04:32 PM
i3arracuda's Avatar
You just get the 19x9.0 wheels, summer tires and Brembo brakes. All the suspension components from the 2010 Track Pack are standard on all 2011 GT's. I think you need to get the 3.73 rear axle in order to get the tuned ESC.
As far as I know you cannot swap out the wheels with any others.
Old Feb 4, 2010 | 05:23 PM
coolmac's Avatar
Dust boots and seals would be great, if you over heat the brakes doing HPDE
The 19 X 9 look good, but I prefer a light 18 X 9.5 square setup, running 275/40/18 rubber.
Old Feb 4, 2010 | 05:27 PM
06GT's Avatar
I'll let you know...going for my first HPDE with the GT500 calipers (same setup as the '11) in a week. The boots on the stock calipers were ROASTED when I took them off!
Old Feb 4, 2010 | 09:14 PM
PTRocks's Avatar
Here's some info from groot, as he posted on another board last week:
Originally Posted by groot
Track Pack (as an option package) has gone away.
The tuning on the Manual Brembo Package Coupe is very close.... only very slight damper tweaks (a split bleed here and a slight change there). Spring rates and bars are the same (we did go to a grippy front bar, so the front spring rate comes down and the grippy bar contributes that lost rate). Marketing does not want it called "track pack".... it does include Brembos, which the 2010 did not, maybe that's why.... not sure.
Also, talking about lap times at Laguna:
We weren't going that fast in that car with me driving. 1:56 was the best I managed in 3 sessions in that car, my first 3 sessions at Laguna. The next day it ran a 1:47.3 with Gunnar Jeanette at the wheel. I am not nearly as fast as he is.
Old Feb 5, 2010 | 06:24 AM
watchyagonnado's Avatar
It sounds like the car wont be lowered at all with the Brembo package, Is that true?
Old Feb 5, 2010 | 06:31 AM
Boomer's Avatar
Chris...link to that thread?
Old Feb 5, 2010 | 08:21 AM
PTRocks's Avatar
Comment1
Comment2
Old Feb 7, 2010 | 07:50 AM
blksn8k's Avatar
Since the 2011 Order Guide states that the Brembo package is not available on the GT/CS would it even be possible to add the Brembos later, considering that the GT/CS comes with 19x8.5 wheels? I'm thinking I would go with the GT/CS and upgrade the brakes and tires when the original tires and/or brakes wear out. Would probably be ready for a performance tuner by then as well so tire size changes would not be an issue.
If the Brembos are the same as on the GT500 then those wheels should work as well, no?
Old Feb 7, 2010 | 07:56 AM
PTRocks's Avatar
It all depends upon the wheels clearing the brakes. If I recall, non-GT500 rims needed spacers.
Old Feb 7, 2010 | 08:58 AM
Depends on the offset and thickness of the inner rim. The GT500 has had 18" wheels since it was released, but they were 18x9.5" with a different offset. It would make sense that if 18" GT500 wheels clear them, then 19" wheels should. But it's not that simple; even the 20" Razors have two different offsets for the front size on S197s. One clears the Brembos, one doesn't.
Old Feb 7, 2010 | 12:45 PM
06GT's Avatar
It's more about the design of the spokes than the offset. At this point, it's mostly a test-and-see type thing
Old Feb 7, 2010 | 02:00 PM
mwilson7's Avatar
The Cal Special wheels will not clear the brembos due to the offset.
Old Feb 7, 2010 | 04:06 PM
True. Really, all of those are variables to consider though.
Old Feb 8, 2010 | 01:57 PM
Barnard 33's Avatar
What makes the ESC tuning for the Brembo package unique? Is it specifically for the summer-only tires? Or does it simply lessen computer intervention during aggresive driving?
Old Feb 9, 2010 | 06:29 AM
First Stang's Avatar
Strut Tower Brace
The strut tower brace is included with the package as well
Old Feb 9, 2010 | 07:42 AM
jeff s's Avatar
Canadian order guide says it includes "unique front corner modules", whatever those are.
