2010 Roush 427R poor dyno results
Old Oct 1, 2013 | 11:20 PM
Encardyle's Avatar
Exclamation 2010 Roush 427R poor dyno results
Hi there
I recently purchased 2010 Roush 427R.
It's a 4.6 v8 3v motor with roush m90 supercharger.
6lb boost. Has 28xxx miles.
Roush claims it's 435HP. And to my knowledge after reading people comments on different forums, on bone stock it's around 375 to 385. Depending on conditions.
Now I was planning to get things done to it as any other guy would want to upgrade lol. I got all the parts and did a pre run on dyno to get numbers for before and after comparison.
I was shocked to see my car is only pushing 314horse with 279 torque first run and 313 second run.
That's less then what my previous 08GT was giving with just aftermarket headers.
What are your suggestions on it. Is it something wrong with the tune? The problem with dyno or it's operator ? Or something wrong with the motor.
Ohh btw the results are from dynojet. And when he was doing the dyno I was really low on fuel. Could that be a reason ?
Also I would like to say that 2 days back. I raced a 04 m3. He had bolton done it. I was dead even at 1/4 miles from dig. So I don't think so a 313 hp car can keep up with m3 on boltons.
Would appreciate your thoughts on it.
Old Oct 2, 2013 | 04:21 AM
wiz_of_wuz's Avatar
I will tell you its a dyno Issue IMO..... I owned a 427R with the smallest pulley and LT's and she smacked down 430 flat to the rear wheels..........
Old Oct 4, 2013 | 07:44 AM
Reminisce's Avatar
Yeah try another dyno. Friend of mine's father had one and put 381 down stock. Unless something is absolutely wrong with your car, I'd try another dyne shop to be certain
Old Oct 4, 2013 | 05:08 PM
Ltngdrvr's Avatar
Yeah, should be better than 314, quite a few I've seen have been in the 350 range.
Maybe a dyno issue but of course could be something else.
Do you have a boost gauge and an A/F gauge? What are the numbers?
Old Oct 4, 2013 | 07:25 PM
2011 Kona Blue's Avatar
Originally Posted by Encardyle
Hi there
Bro, there is no way your car is making 313 rwhp and 279 rwtq. You have a supercharged V8 Roush 427R. The dyno machine had to be jacked up. You have to be at least 370 rwhp and most likely a hair more. Go get another dyno.
Old Oct 4, 2013 | 08:21 PM
Ltngdrvr's Avatar
There could be lots of reasons it isn't making more power.
Old Oct 5, 2013 | 05:12 AM
Unless that dyno is right and there is something wrong with the car itself before he bought it... Esp at 20,xxxx miles.
Old Oct 5, 2013 | 07:49 AM
Ltngdrvr's Avatar
Could be an old belt causing lots of slip, could be something else, that's why I was asking about gauges so we might have a little more insight into the conditions.
Old Oct 5, 2013 | 09:18 AM
Also, what gear was the car in when they did the pull?
Ray11
Sep 25, 2015 12:43 PM
