1st oil change question,Mobil 1 ?
My 2013 mustang GT has 4000 miles on it, time for its first oil change.
My question is, is Mobil 1 synthetic ok to use ? I would think it is. Lots of posts about ticking after oil changes and I was wondering if anyone had a problem with the Mobil 1 oil. Thanks in advance. |
That's what I use, except I did the first change around 1K.
Mobil1 and a motorcraft filter are all you need. |
Used M1 on my 400 mile oil change. Haven't changed it again yet but will do an oil analysis when I swap oil later this month. Will post results
I don't think you can do much better than Mobil 1 with a motorcraft filter.
I figured I would ask as ticking seems to happen with some oils. Thank you |
Originally Posted by Victory-rc
(Post 6726582)
I don't think you can do much better than Mobil 1 with a motorcraft filter. I figured I would ask as ticking seems to happen with some oils. Thank you
Buy a mustang GT and not change the oil ? :bad:
You have to do it anyway so take the jump. Change da oil.
It's stupid not to change it.i don't get why you wouldn't do it
(Post 6726731)
My dealership is giving me two oil changes free, and I'm going to use the first one this month, as I'm at 5100 miles and haven't changed the oil since 400 or so miles. I am very interested to see the oil analysis results of my current M1 compared with Motorcraft once I change it next, likely in the June timeframe.
Always have had good luck with M1 - I ran it for the 4 years I had my Audi S4, and I pushed that car hard (tracked it). The oil regularly got up to 275F when I had that car on road courses. |
M1 here also. Went ahead and bought filters and oil to do 4 changes.
We run Redline, one of the few larger companies that offer an actual full synthetic. Mobil used to but thanks to Walmart they are no longer a full synthetic oil.
Originally Posted by Jay@Hypermotive
(Post 6727141)
Jay, I thought Mobil 1 EP (extended performance) was full synth? Not the regular Mobil line... |
Originally Posted by FromZto5
(Post 6727164)
That's why I run Amsoil always. Jay, I thought Mobil 1 EP (extended performance) was full synth? Not the regular Mobil line... |
Originally Posted by 2012GT
(Post 6727187)
Mobil 1 synthetic Extended Performance is base four synthetic stock. Mobil 1 synthetic is a base 3 stock. Get the extended performance and you have a base four synthetic just like AMSOIL and royal purple.
I just wanted to correct misinformation. |
Anyone run Joe Gibbs? They sell it up at my work, so I can get it at cost.
http://www.carshopinc.com/product_th...g&w=1000&h=750 |
I had a engine built for a Buick grandnational by Kenny duttweiler a few years ago, he recamended synergyn (spelling ?).. Stuff was weird to say the least,get it on your hands and thinner/gasoline wouldn't remove it,but it was expensive.
I have used Mobil 1 for years with good luck,I would think its fine for the GT. |
(Post 6727164)
Jay, I thought Mobil 1 EP (extended performance) was full synth? Not the regular Mobil line... Yeah, I should've clarified. Most individuals who purchase Mobil 1 I've seen don't buy the EP. |
I think 4,000 miles for the first oil change is a little too long......Just saying :)
Ok so I am curious......OIL or errrr SYNTHETIC.......same princples to lubricate and reduce fricition between parts. Ok I am curious....change your Oil at 400 miles, 3000 miles, or when the Oil Life on the car says too??? Common practice versus personal preferences......I on the fence as to when I should change....I have a brand NEW 14 V6 base....I am sold on the Synthetic...most likely Mobil 1 EP since I can get here and not have to order in like Amsoil....
