18 x 9.5 Rims, What tire size?
Old Apr 18, 2012 | 08:55 PM
GtStang4's Avatar
Replacing the stock 17 x 7 rims and Michelin P215/65R17 tires on our 2011 V6 with 18 x 9.5 rims and ? what size tires? Where is a good site to calculate the correct tire size to maintain the correct diameter? Don't want to effect the speedo. Has anyone already been through this and know the correct size? Thanks
Old Apr 18, 2012 | 10:02 PM
Ltngdrvr's Avatar
Those are the tall V6 tires, 28" tall.
A 275/45-18 will be closest at 27.7" tall and will make your speedometer read just slightly faster.
Here's the best calculator I have found: http://www.1010tires.com/TireSizeCalculator.asp
Old Apr 18, 2012 | 10:06 PM
jsnyng's Avatar
TireRack also has that size in Continental DW's for $100/ea - http://www.tirerack.com/tires/tires....ECDW&tab=Sizes
Pics here on my car w/ 18x9.5 - http://www.flickr.com/photos/jsnyng/...7629461859643/
Old Apr 19, 2012 | 08:19 AM
GtStang4's Avatar
Thanks for the info. $100 each, that is a great deal. Are they any good for an everyday driven car?
Old Apr 19, 2012 | 08:23 AM
Ltngdrvr's Avatar
Sure hope so, I have a set sitting here waiting for wheels!
Old Apr 19, 2012 | 08:24 AM
jsnyng's Avatar
Absolutely! They are usually a $289/ea tire. I'd even be comfortable autocrossing in a street tire class on them. I run -2.7 camber and have 4k miles on mine so far. There is no visible wear whatsoever on the fronts or rears.
Old Apr 20, 2012 | 09:50 AM
GtStang4's Avatar
Spoke to Tire Rack, they recommend a 255 45 18. Say the 275 might be too wide for the front. Anyone know if this is correct? Thanks
Old Apr 20, 2012 | 10:20 AM
DUFUS's Avatar
Barring an unusual wheel offset, there should be no problem with 275 in front. I've got 275-40 on 18x9.5 with 45mm offset. I had to oval-ize the brake ducting I had added a bit, but no worries.
Old Apr 20, 2012 | 10:28 AM
GtStang4's Avatar
I have the Steeda Q1C 18x9.5 rims which are 45mm offset also. Does anyone make some type of steering limiter kit if they would happen to rub?
Old Apr 20, 2012 | 10:50 AM
jsnyng's Avatar
I've run 275, 285, and 295 up front with no problems on an 18x9.5 +45.
Old Apr 20, 2012 | 11:23 AM
Dave07997S's Avatar
A 9.5" wide wheel will properly support a 275 tire, any wider you should move on to a 10"+ width. I would go with a 275/40/18 at 26.65" tall, this would be your best bet. A 275/45/18 tire is to tall.....
Dave
Old Apr 20, 2012 | 11:24 AM
Dave07997S's Avatar
Normally a 295 tire requres a 10" wide wheel to be safe. Most manafacturers list a minimum rim width of 10" for a 295 width tire.
Dave
Old Apr 20, 2012 | 11:47 AM
Kevindust's Avatar
I am running 275/40/18 on all four corners with 18x9.5" (GT500 take-off) wheels. The tires mount nicely on the wheels and I've never had any problems with the tires rubbing or uneven tire wear. I will stick with the same size for my next tire purchase.
Old Apr 20, 2012 | 12:02 PM
jsnyng's Avatar
Dave
275/45/18 is still shorter than what he's got now. 275/40/18 is considerably shorter.
Dave
Agreed, but a 295/30/18 Hoosier A6 is just fine with its stiff sidewall on a 9.5 wheel.
Old Apr 20, 2012 | 04:51 PM
Dave07997S's Avatar
True, but the Mustang in its performance variants are running a 255/40/19 which are 27" tall as is the 285/35/19 for the LS and GT500, so the 275/35/18 at almost 26.7" tall isn't that far off. A 27.6" tire is just to tall IMHO for it to be performance oriented. I didn't know the base car had such a tall tire..yikes.
You never mentioned in your post about running a Hoosier R compound, even then Hoosier recommends a 10" wheel for a 295/40/18 for the A6. Will it fit, yes but it won't be optimal.
On my M3 I run a 285/30/19 out back as I am running a 19X10" wheel, but a 295 is pinched even though it is approved for this width.
Dave
Old Apr 21, 2012 | 03:46 PM
GtStang4's Avatar
Tire Rack raised price to $108, says less than 12 available. Also shipping from Nevada which increased shipping cost. Ordered them anyway before all gone
Old Apr 21, 2012 | 04:29 PM
kn7671's Avatar
Awesome price on a great tire, get em while you can. I've got about 15k on my Conti DW's now, like them a lot.
Old Apr 26, 2012 | 11:22 PM
tetstang's Avatar
This is good info. I'm looking to switch my OEM 19"x 8.5" nickel wheels for Steeda (or equal, with 45mm offset) 18" x 9.5" rims, on all four. I'd prefer to mount 275/45-18's, and that setup will be the very same OD as my OEM's at 27.7" tall ( 245/45-19).
- Question is, will that fitment work up front without any issues on a stock GT? ( I noticed you have suspension mods. )
Thanks,
TS
Old Apr 27, 2012 | 07:16 AM
jsnyng's Avatar
You're going to be fine on stock suspension.
Old Apr 28, 2012 | 08:26 AM
tetstang's Avatar
Thanks !
