New Torch Red Mod
I lust for a M24
Yeah, it's much better. Now it's almost too quiet, but I'm leaving as-is for now. I do have a little vibe in the right rear I need to get figured out, it happens during certain RPMs. I saw a thread about fixing that, but I need to find it.
Notice the heat-shields I added to the gas tank? A little "just-in-case".
I'm assuming you know this, but that's the panhard bar, not the sway bar. (maybe someone else would be confused )
John,
Yeah, knew what it was, can see your sway bar next to it.
Interesting heat shield mod. The tanks do already have a shroud over them, so the mufflers won't actually touch the tanks themselves.
I only had about 1/4" clearance on mine, but still tucked in a piece of some aircraft firewall seal between the muffs & tank covers, mainly to eliminate vibration noises.
Probably the only thing you can add to make it a bit louder would be some hi-flow cats to the existing exhaust.
Or, go LT's
I'll have a vid of my current setup here within a week, I'll post the link when I get it up.
Or, go LT's
