Street Scenes Foglamp Wiring
Here is The Street Scenes Foglamp Wiring Kit Instructions. It can Be used for The Street Scene V6 to GT fOG Grille Conversion . It Could also Be used for the Pony Package Conversion if the FOG Pigtails are Changed.
[attachmentid=32206]
Originally posted by Mustang Mike 05@August 30, 2005, 12:52 PM
The complete grille conversion kit and wire harness kit are now available!
Originally posted by 05stangkc@August 30, 2005, 4:50 PM
The Grille Does not Include the Wiring. I am A Street Scenes Dealer. I have a Street Scenes HOTSHEET Available upon Request.
kc
kc
Thanks Kevin. Got it from you. You have the Center mounts listed for the V6, but those ar NOT currently available yet correct?
Originally posted by 05stangkc@August 30, 2005, 6:33 PM
I will ck For Current Center Mount eta Tommorrow. I believe all of the {SHELL} Part Numbers are Getting Close to Release.
kc
kc
OK Street Scenes Update!!!!!!!!!!!!!!As Per Mike@S/S Email
The Foglamp Wiring Kit is Triggered by the Headlights. They Can not be Turned on without the Headlights being on. So you can not Leave the Fogs on Without The Headlights being on. So no Worries about leaving them on Accidently.
The V6 Grille Shell with Gt Style Foglamps are Now Available.
The Gt Center Mount Grille Shell is 1to2 weeks out.
The V6 Center Mount Grille Shell is 2 to 3 Months out.
This is the Best Info at The Present.
If you would Like a STREET SCENES HOT LIST please email me @ clevparts@aol.com
If you had the Harness, Switch and I believe a Relay I believe it could be done. I would estimate about $400.00+. Some I have Heard have pieced a Harness together but I do not have all the Specifics. The S/S Kit is a Far more Cost effective way to Go! I have yet to check an 06 Non Pony V6 to see if wiring is already there.
kc
kc
I have already wired them to the underhood junction block and used the Ford relay and Headlight switch. I used a seperate wire from the fog light switch to the underhood junctionblock to ground the relay because the smart junction block won't turn it on because it is not programmed for foglight operation. I went to the dealer and they charged me $50 to tell me they couldn't reprogram it. Is it reprogrammable or not? I would prefer to have it operate through the SJB beacuse it would then turn off the fog lights if you left them on by mistake and also turns them off when you put on the highbeams.
kc
