IUP Door Handle Upgrade+ New Emblems
Originally posted by 05stangkc@February 15, 2005, 2:50 PM
YR3Z16098bb and YR3Z16098AA I stock these!
KC
KC
Originally posted by kevinv-6@February 18, 2005, 3:01 PM
I kinda copied 05stangkcs' idea(hope you dont mind)
they are vinyl. here is the link:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...7959528582&rd=1
Originally posted by raekwon888@March 8, 2005, 1:27 AM
was it hard to install the door handles.how the heck did u change them
The Handles and Pony Emblems Are Still a Bargain! Get them before Ford raises prices like they are doing on the Sill Plates! I have these in stock for all colors!
kc
kc
Originally posted by 05stangkc@February 12, 2005, 2:22 PM
[attachmentid=11835] [attachmentid=11834] [attachmentid=11836] [attachmentid=11837]
Here is a little Door Panel dress up I did on my Gt. I got a couple of 98-04 fender emblems rt & lt and put them on my door panels. Once you get the emblems you will have to trim off the locating tabs unless you want to drill holes! {NO THANKS}.
I used side cutters and a xacto blade. Make sure you cut below the adhesive so it does not high center! I used a little Denatured Alcohol on a Clean rag to get any oil residue off the panel. Please use sparingly to avoid damage. Or you could use some soap & water. DO NOT use something caustic like carb spray! Position LIGHTLY and stand back to see if it is level. Reposition and if its good, Press Hard and you are done! Oh by the way I positioned mine so the Horses are running forward! Hope this Helps anybody looking for a little dressier door panel. This may not work as well on the IUP panels with the upholstory on the door. If you try it on those the alcohol may be a bad idea.
i tried to get an emblem to stick to the black part of the dash( between glove compartment and metal IUP trim) it just wont stick, I have used windex, 70/ 30 rubbing alcohol, water mix. I gave up and put it on the metal trim for now, but I want to put emblems on the IUP door panels, any suggestions???
Originally posted by harrier@July 29, 2005, 10:17 AM
Dave, i got my black double-sided tape from wal-mart in the automotive section. it's should be right next to the touch up paint and headlight bulbs.
