Originally Posted by 2k7gtcs
(Post 6500984)
I'm still traditional and I'd hope the young man would be too. I wouldn't put much credence into a boy that didn't drive his date to the prom.
And he is 2. well I imagine you'll have a couple more cars by then! |
Originally Posted by Shelby08
Sadly (at least up here) most guys her age don't have those traditional values/habits that I was brought up with. well I imagine you'll have a couple more cars by then! Unless they strike oil on my land in which case I'll add a Ford GT. But that won't happen anyway. |
(Post 6500992)
Only one more. The Shelby. After that I'm done.
So back to laying claim to Gary's cars... No one ever actually claimed seven. Sooo mine!
(Post 6501004)
You guys might wanna spend some time researching. I'm pretty sure all of his rides are claimed, mostly way before you showed up
Originally Posted by Scothew
(Post 6501011)
(Post 6500992)
His rides have been claimed so many times, it's not even funny anymore. :p
I just plain refuse to believe this :grin: Torque bar, panhard rod, k-member, camber/caster plates, MM A arms for coil overs. :devil: |
(Post 6501034)
You're gonna love the goodies I got for the Notch this week from MM.
Torque bar, panhard rod, k-member, camber/caster plates, MM A arms for coil overs. :devil: edit: also what coilovers are you running/planning on if not the MM ones? |
Consider me as green as my bullitt is :drool: |
Consider me as green as my bullitt is :drool: edit: also what coilovers are you running/planning on if not the MM ones? Anyway I plan to use their coilover conversion for the fronts with my illumina Tokicos. On the back ill run their regular springs made to work with the torque arm and use their adjustable LCAs. The cool thing about the torque arm and panhard setup is that it eliminates the UCAs which as you taught me is the real problem with these cars and the snap steer. |
That notch is going to HAUL :nice:
take lots of pics of the install if you can. I eventually would like to have a lot of those bits on my car someday. this way i can cheat and see what was hard before I get to it :jester: |
Well the fist step will be the subframe connectors. Had them for years and never put them on. Can't install the torque arm without it because it gets welded to them |
Originally Posted by lime05
(Post 6501586)
Is it time for a notch thread!?
Well we have a problem with the Bronco. Whenever the temperature drops the seals on these **** El Dorado rear brake caliper leaks. Just the drive side. I heard this could be an issue in colder climates. ****ing GM!
(Post 6517622)
(Post 6517622)
(Post 6517626)
Putting GM parts on a Ford :shame: :jester:
Gary<-----:banned: |
