6.2L BOSS Engine Pics
Old Oct 29, 2009 | 08:27 PM
Red Jay's Avatar
browsing around on another forum and saw this. thought id share with the mustang community
After a guy asked if it was from a 6.2 that blew up..
No it didnt blow up but we are going to do some r&d. It was in a 3800lb car that went 8.50's on the stock bottom end..
pics:
Old Oct 29, 2009 | 08:44 PM
MARZ's Avatar
Swamp Donkey Aficionado
Nice find. I doubt Ford's going to be happy with whomever posted these pictures, though.
Old Oct 29, 2009 | 08:50 PM
The Boss is Back!
07S197's Avatar
Swamp Donkey Man Cans
Hahaha I like that...... "The Boss is back"
So umm what does Ford build that weighs 3800 lbs???
Old Oct 29, 2009 | 08:52 PM
Old Oct 29, 2009 | 08:55 PM
A Falcon?
Old Oct 29, 2009 | 09:00 PM
07S197's Avatar
Humm could be. But I though there was a car built off of the Falcon platform.......dang though, the name of it escapes me at the moment.
Old Oct 30, 2009 | 04:25 AM
Dig-It Racing's Avatar
Sweet.
Old Oct 30, 2009 | 08:19 AM
Boomer's Avatar
A test car like they always do 'just cause'
Doesn't mean anything will come of it
Old Oct 30, 2009 | 08:37 AM
07S197's Avatar
Doesn't mean anything won't either......becides it fun to dream. Maybe a new version of the FR500CJ
Old Oct 30, 2009 | 08:42 AM
I don't understand Boomer.
You have not denied that the Boss 6.2 is going into A car and not just the F series, but that it is not going into a Mustang. Looking at the line-up there is nothing else it could even wedge into. Festiva, Fusion, Focus, Taurus. Am I missing a car?
Old Oct 30, 2009 | 08:58 AM
07S197's Avatar
Maybe a global RWD platform in the works? They need something new to put up agenst the Chrysler LX platform & the GM SSP/FLeet Caprice. 3800lbs. seems kinda light though, had to be in a Mustang.
Or we are just grasping at nothing.....
Old Oct 30, 2009 | 09:11 AM
I agree it was probably in a Mustang for testing, but I was just remembering what I thought Boomer had said in previous posts on other threads.
Old Oct 30, 2009 | 09:50 AM
hi5.0's Avatar
That's sad when 3800 lbs. "seems kinda light" if the test platform happened to be a Mustang. No thanks to GM and Dodge building pig-heavy pony cars. Perhaps the segment name should be changed to "Clydesdale" to reflect the increase in size, weight, and power.
Back on topic - those 6.2L heads look huge, the same can be said for the cam gear/sprocket too. VCT mechanism? Had to smile at "The Boss Is Back" casting.
Old Oct 30, 2009 | 01:13 PM
Blainestang's Avatar
Well, all the "Pony Cars" are in their 40's, now, so their bound to put on a few pounds.
(Actually, I agree... the Mustang is overweight, IMO. It only seems OK because the others are downright obese)
Old Oct 30, 2009 | 07:35 PM
Red Jay's Avatar
one more.....rocker arms arent gonna be used again are they?
Old Oct 30, 2009 | 07:41 PM
jsaylor's Avatar
Canted valves with a SOHC.......without some very high tech stuff there is no other way around it. But don't fret, this is going to be the big dog of the truck engine world, massive torque and good fuel economy considering the size and application. If you want big power and in a full size truck and a diesel isn't an option this is the one to get.
Old Oct 30, 2009 | 07:47 PM
Can't wait to be able to get my Raptor 6.2
Old Oct 30, 2009 | 08:03 PM
Red Jay's Avatar
might not be anything new but oh well..
this says the production block will be cast iron:
Key features of the new 6.2-liter V-8 gasoline engine include:
• Cast-iron engine block and four-bolt main bearing caps, with cross bolts, for durability
• Aluminum cylinder heads, with two valves per cylinder and two spark plugs per cylinder
• Cast-iron crankshaft, with dual-mode damper
• Forged steel connecting rods
• Cast-aluminum pistons, with cooling jets
• Single overhead camshaft with variable valve timing and roller-rocker shaft valvetrain
• Magnesium cam covers for lighter weight
• Stamped-steel oil pan
• Composite intake manifold
• Stainless-steel fuel rail; port-fuel-injected; mechanical returnless fuel system
• 9.8:1 compression ratio
• E85/flex fuel capable
Source in APA format
Turner, S. (October 9, 2009) An all-new 6.2-liter V-8 gasoline engine. 5.0 Mustang and Super Fords Magazine.
Retrieved October 29, 2009 from An all-new 6.2-liter V-8 gasoline engine | Miscellaneous Blog & Discussions at 5.0 Mustang and Super Fords Magazine
Old Oct 30, 2009 | 08:06 PM
Sounds good to me. Cast iron block, aluminum heads, cast iron crank, and forged connecting rods.
Sounds strong.
