Will 07 gt bullitt wheels fit on a 95 gt and what size tires
Old May 13, 2014 | 02:17 AM
Mike1234's Avatar
I bought a set of bullitt wheels from an 07 mustang gt
The bolt pattern is right but what size tires do I need to make them fit??
I have a 95 mustang gt
Old May 13, 2014 | 02:24 AM
Mike1234's Avatar
07 gt bullitt wheels on a 95 gt
Will they fit on my 95 gt and what size tires would I need?
The bolt pattern is right but would I need a spacer?
Old May 13, 2014 | 12:48 PM
Xplosiv's Avatar
From what I understand they should be the same size the bullitts that came on the 99-04. I would say a 245/45/17 (factory 99-04 gt tire) would fit no problem.
Old May 13, 2014 | 01:11 PM
Originally Posted by Mike1234
I bought a set of bullitt wheels from an 07 mustang gt The bolt pattern is right but what size tires do I need to make them fit?? I have a 95 mustang gt
You'll need 1" spacers to make them look decent. The offset on S197s is much higher than SN95s (which already come with wheels that are too tucked in, IMO) which would result in the wheels being super tucked in. You also need shorter SN95 height tires, as mentioned above. For those wheels, 255/40/18 would be good.
Old May 13, 2014 | 01:38 PM
Xplosiv's Avatar
I thought the bullitt wheels on the 05-09 stangs were still 17's?
Old May 13, 2014 | 01:41 PM
True, the standard GT wheels were 17x8, but there were optional 18" Bullitt style wheels too, so for the 18s 255/40/18s would be good, for the 17s you'd want 245/45/17s.
Old May 14, 2014 | 01:44 AM
Mike1234's Avatar
Thanks guys
How about 245/40/18 would that work?
http://www.discounttire.com/dtcs/sea...18&x=23&cs=245
Old May 14, 2014 | 04:41 AM
Evil_Capri's Avatar
https://themustangsource.com/f693/s1...s-sn95-477005/
Old May 14, 2014 | 04:42 AM
Evil_Capri's Avatar
Merging your threads, but will leave a link for a few hours . . .
Old May 14, 2014 | 09:21 PM
The Mad Dooby's Avatar
I had these on my 95 GT. I had 1-inch spacers all around, with 235/50 tires in front and 245/55s out back
Old May 14, 2014 | 09:55 PM
Mike1234's Avatar
Awesome thanks for the feedback ... 245/40/18 should work perfect then
I was also thinking these for the spacers
Amazon.com: 4 Ford Mustang Wheel Spacers Adapters 1 inch fits ALL 5 lug Ford Mustang models: Automotive Amazon.com: 4 Ford Mustang Wheel Spacers Adapters 1 inch fits ALL 5 lug Ford Mustang models: Automotive
tdf017
Aug 5, 2015 10:13 AM
