Transciever location?
Old Mar 16, 2015 | 11:48 AM
Jim74656's Avatar
Ok I know the 2004 Mustang (car in sig) uses the transponder chip, now I know the key has the RFID tag (if you will) what I am wanting to know is where is the reciever (car side) is it the ignition ring that goes around the key insertion point or is it the thing that wraps around the key head once its inserted?
thanks for the help so far and educating me!
Old Mar 16, 2015 | 09:03 PM
houtex's Avatar
It's inside the column, you don't see it. http://www.ebay.com/itm/1999-2004-99-04-FORD-MUSTANG-PATS-HALO-KEY-IGNITION-SYSTEM-ANTI-THEFT-OEM-00-01/161610415047?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D28772%26meid%3D9e138e5883d44bd0a3d8a8c270d08200%26pid%3D100011%26rk%3D1%26rkt%3D1%26sd%3D151441898304
The halo sends the power and picks up the signal. If you rewatch that column disassembly video, you'll see how he takes it off to get the clockspring wiring loose.
Old Mar 16, 2015 | 09:25 PM
Jim74656's Avatar
Ok so as far as the piece that "surounds" the head of the key is safe to mod a bit is what I am getting from your statement, thanks! going to start planing the mod to make my new keys fit!
thanks houtex!! helpful as ever!!
oneeyedgiant
Nov 16, 2015 12:23 PM
RoushRS3
Sep 29, 2015 08:03 PM
TerryD
Sep 28, 2015 11:48 AM
