Shaking
Old Nov 1, 2005 | 09:53 PM
Gattguy47's Avatar
when I am slowing down from highway speeds, which is like 110-115 km/h. as soon as I start applying the brakes, my steering wheel starts to shake. Does anybody know why it would do this? how can I fix it?
Old Nov 2, 2005 | 01:08 AM
jgsmuzzy's Avatar
sounds like you may have a warped brake disc. they are not expensive to replace (do the pads at the same time) and that should sovle it.
J
Old Nov 3, 2005 | 12:01 PM
y2kcobrar's Avatar
You don't really even need to get to rotors replaced, unless they are warped really bad. Just get them "turned" and replace the pads to match with the new surface the rotors will have and you should be fine. Just did the same thing to mine. Warped the left front shortly after I got her due to some high speed braking. Got the rotors resurfaced and pads and the shake went away.
Old Nov 3, 2005 | 12:42 PM
Knight's Avatar
Needs to be more Astony
Could be wheel alingment or worn out bushing.
I had that problem once and the bushings for the tie rods were completly gone causeing my whoile wheel to shimmy front to back under braking. It problay isn't this problem but it could be.
Old Nov 3, 2005 | 03:38 PM
conv_stang's Avatar
heck with the price of new replacement parts its cheaper to buy new rotors than to have them turned down.
Old Nov 3, 2005 | 05:29 PM
bullitt5177's Avatar
I recommend that if you're going to replace, then upgrade!!! Get drilled/slotted rotors with high performance brake pads!!
Old Nov 6, 2005 | 10:51 AM
DanS.02GT's Avatar
Once you've either turned or replaced the rotors, bedding them in will reduce the chances of the problem coming back.
Old Nov 18, 2005 | 04:34 AM
y2kcobrar's Avatar
Hey Dan, wanna let everyone know WTF "bedding in" is? I assume its break in, but what's the protocol for somethin like that...run it to 150mph and stand on the peddle?
J/K, I'm being sarcastic...
Old Nov 18, 2005 | 04:36 AM
jgsmuzzy's Avatar
what is it, do not brake heavilly for the first 200 miles or something like that.
Old Nov 19, 2005 | 11:44 AM
Fordracing200's Avatar
my dad's F-150 does the same thing, ours is from warped brake rotors, i suspect thats what your problems is too, Buying new ones should fix this, and while your their you should replace the pads too, also this is usually caused from poor break-in practices.
Old Nov 21, 2005 | 08:12 AM
jgsmuzzy's Avatar
not really,
if you are doing 100mph and brake really hard to a stop, this can warp the discs due to the phenomenal temperatures generated. I always break the pads in gently, and had still suffered with warped discs (only once mind, it is not a common occurence). But as the discs are fairly cheap, and fairly easy to fit, it is not a problem.
05GT4.6
Sep 7, 2015 11:06 PM
robjh22
4.6L GT Modifications
Aug 13, 2015 02:56 PM
94tbird
Apr 13, 2005 08:56 PM
J2snoop
1994-2004 V-8
15
Mar 9, 2005 12:30 PM
95GT
1994-2004 V-8
14
Jan 12, 2005 09:01 AM
