Oil on spark plug threads??
Old Mar 3, 2012 | 01:33 PM
stang95work's Avatar
Anyone kno if this is oil from valve cover gasket or raw fuel?
Old Mar 3, 2012 | 02:25 PM
If the plugs were tight, the sludge is below where the plug seals with the head - so it couldn't be from the cam cover gasket. Do you have signs of the cam cover leaking?
Why the rust? Engine wash gets under the plug boot?
Old Mar 3, 2012 | 04:35 PM
wow thise are nasty looking. Can you post a better picture of the threaded parts for me/us?
Did the plugs seem tight when you loosened them and while you spun them out?
Old Mar 3, 2012 | 06:53 PM
McNassty's Avatar
WOW!!! Looks like ya shoulda changed those about a year ago
Old Mar 3, 2012 | 06:57 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Sn95 buddy... most likely a 5.0 without coil overs
Old Mar 3, 2012 | 07:03 PM
thought sn95's were 4.6 OHC's.
hmm... wiki says not till 96...
Old Mar 3, 2012 | 07:18 PM
Bear Eats King...
Bear ****s Bone
Sn95 is 94-98
Old Mar 3, 2012 | 07:22 PM
Sn95 is 94-98
94-04
says 5.0 pushrod was 94, 95, then 4.6 2V OHC from 96 - 04.
"1996 was the first year for the 4.6L Modular V-8. The GT model was a SOHC at 215 horsepower, and the Cobra model was a 32-valve DOHC at 305 horsepower. Taillights in 1996 were changed to a vertical tri-cell design more like first generation Mustangs. "
https://themustangsource.com/timelin...8/96/index.htm
new edge is just marketing blah with some cosmetics. like the 10 diapermobile of the S197
1999 marked Mustang's 35th anniversary, and Mustang got a fresh new look. Though still based on the Fox platform, the smooth lines from 1994-1998 were replaced with an edgier design.
https://themustangsource.com/timelin...4/99/index.htm
Old Mar 4, 2012 | 02:38 AM
McNassty's Avatar
Ya might wanna check your title and make sure it's not a salvaged title. Spark plugs shouldn't have rust on them unless the car has sat. Electric spark repels rust, so there should not be any rust on your electrical components unless it has sat
Old Mar 4, 2012 | 03:11 AM
McNassty's Avatar
My bad, answered before i checked my info, water has gotten under the boots which you could use boot lube and anti-seize compound on your new plugs. Sorry, never had this problem so I was guessing. But from what I've read this shouldn't happen unless the plugs aren't gapped right or the boot isn't seated right. Or also you could have a head gasket leak
Old Mar 4, 2012 | 03:15 AM
McNassty's Avatar
And I've had three V-6 3.8's and they are notorious for blowing head gaskets. Ya just can't run the A/C's in traffic it seems for long without burning those head gaskets. Might have something to do with the aluminum heads. I got lucky and mine was under warranty
Old Mar 5, 2012 | 08:08 AM
i think its the valve cover gasket. i havnt had the car very long. its been sitting for a few months in cold weather. the plugs werr very difficult to remove. i replaced them with iridium autolite spark plugs. and yes they werr nasty. the previous owner didnt take care of this. so im trying to slowly but surely restore everything back to mint
Old Mar 5, 2012 | 09:31 PM
McNassty's Avatar
Okay it looks like its too lean or too much oxygen or it's oil fouled. Con you show a pic with the tips?
Old Mar 5, 2012 | 09:35 PM
McNassty's Avatar
Oh and from what I read you might wanna check your air filter
Old Mar 6, 2012 | 07:03 AM
Bear Eats King...
Bear ****s Bone
That's one old old old picture its not the air filter. That picture is back when carbs were used. A clogged filter would draw in for fuel from the Carb. Modern injection systems do not do that.
Old Mar 6, 2012 | 08:43 AM
McNassty's Avatar
My bad, had a drink (or two) last night and saw this thread again and decided to surf a little on it and found a couple of pics. He really should take a pic of the tips and post it though
Old Mar 6, 2012 | 09:02 AM
Bear Eats King...
Bear ****s Bone
I completely understand lol
Old Mar 6, 2012 | 09:35 AM
the tips werr unharmed. just the threads.
Old Mar 6, 2012 | 09:36 AM
id post a pic of the tips but i allready threw them in the trash.
Old Mar 6, 2012 | 09:47 AM
Bear Eats King...
Bear ****s Bone
What year is your Stang? 95?
