Noise while idiling
Old Feb 4, 2012 | 04:08 PM
Ddejesus523's Avatar
Noise while idiling
I hear a weird squeaking noise while idling. I do it's not very loud. I don't think it's coming from the engine. Where I hear it the most is under the car by the drivers door any ideas of what it could be?
Thanks in advance.
Old Feb 4, 2012 | 04:34 PM
Dbranham's Avatar
Does it make the noise while moving. If you can even hear it over the engine.
Old Feb 4, 2012 | 05:56 PM
thats weird. Are you sure its not on the front of the engine?
Old Feb 4, 2012 | 07:45 PM
Lol I can't hear much over the engine but the squeaking sound is there.. But when I popped the hood everything sounded normal. When I checked underneath the car that's when I heard it most. From what I've collected people have told me it can be the bearings in one of my pulleys.
Old Feb 4, 2012 | 08:05 PM
cpotts13's Avatar
Throw out bearing.
If you have a auto then Idk...
Old Feb 4, 2012 | 08:50 PM
Yea it's a manual. What's the throw out bearing do?
Old Feb 4, 2012 | 09:01 PM
cpotts13's Avatar
OH SWEET JESUS...
Hopefully someone can chime in in this one...
I had a 98 cobra that had a throw out bearing that was going bad, it made a squealing/ whining sound. Basically it is a part of the transmission, the part costs like 20 bucks, but getting to it is a whole other story..
Old Feb 4, 2012 | 10:21 PM
Well I just bought a stage 1 clutch that comes with the throw out bearing. So I think that'll fix my problem.
Old Feb 4, 2012 | 11:05 PM
cpotts13's Avatar
Good luck!! Hopefully it will. Tell me how you like the clutch aswell, i am considering it too!
Old Feb 4, 2012 | 11:10 PM
Thanks! I'm having it put in Thursday I'll let you know then.
Old Feb 6, 2012 | 10:56 AM
SVTCobraR315's Avatar
here is a way to test if its the throw out bearing or pilot bearing. i think if it is one of them it would be the pilot bearing. the throw out bearing is only engaged when you step on the clutch pedal. if you press on the clutch and the sound goes away its your pilot bearing. the pilot bearing is what the clutch plates sit on.
Old Feb 10, 2012 | 05:52 PM
I replaced the clutch today and i'm hearing a different noise. When I step on the clutch I don't hear anything. When I disengage it I heard almost a rattling or grinding noise. Also when rev the engine while in neutral it makes the same noise. Any idea?
Old Feb 10, 2012 | 09:46 PM
Pilot bearing. Did they not change that when they did the clutch?
Old Feb 10, 2012 | 11:33 PM
I changed the pilot and throw out bearing. According to the mechanic he says it has to break in. Is there any truth to that?
Old Feb 11, 2012 | 03:52 PM
Hmm I haven't heard of it but it doesn't mean it isn't needed.
Old Feb 13, 2012 | 09:42 AM
Ironically it was the clutch cable that needed adjusting. That was causing the noise from the throw out bearing. What a difference now. The stage 1 clutch is so much better than the OEM.
Old Feb 15, 2012 | 07:58 AM
Bastards "it needs to break in". Punk @$$3$
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Mr. V
Dec 24, 2016 02:57 PM
ricky1728
Feb 11, 2016 07:25 PM
Rando
Sep 30, 2015 12:28 PM
