My 2kGT - Track Whore w/ 5.4L & IRS
My 2kGT - Track ***** w/ 5.4L & IRS
I have recieved some PM's lately asking for a build thread describing my 2000 GT. It's beed dubbed "Frankenstang" mosly because it uses parts from many forms of Mustang as well as some other Ford (truck) vehicles. I bought it new back in mid-2000 when I started my career at Ford as an engineer. Of course it didn't take long before I started to mod it. I started simple with changing out the mufflers, just like 80% of Mustang owners do. I then turned my attention to the suspension, then the brakes. It started to see life on the road course back in 2002 and has been used for that purpose ever since.
Vehicle Details:
Engine
1997 (NPI) 5.4L short block - purchased off craigslist, rebuilt with new bearings & rings
PI heads
Comp XE270AH Camshafts
Comp Valve Springs
Comp Adjustable Cam timing gears
HPS intake manifold
Trickflow upper intake plenum
Trickflow 75mm TB
BBK CAI
Exhaust
BBK O/R X-pipe
High-flow cats welded in
Custom cat-back w/ secondary x (similar to FR500 concept)
Suspension
Front:
Steeda/Eibach Sport Springs (650 #/in)
Tokico D-Spec adjustable struts
Steeda 1.375" Swaybar
Steeda X2 balljoints
Steeda Bumpsteer kit
Steeda Caster/Camber plates
Rear:
2001 IRS assembly w/ 3.55:1 gears
Eibach sport springs (675 #/in)
Tokico D-Spec adjustable shocks
Maximum Motorsports Polyurethane subframe bushings
Chassis & Weight:
Kenny Brown SFC's w/ jacking rails & triangulated for strength
Rear Seat deleted
Mach 460 deleted
Battery relocated to trunk
Brakes
Front:
2001 Bullitt Calipers
Brembo Rotors
Hawk HPS (street) / DTC60 (track) pads
Braided Stainless brake lines
2000 Cobra R brake ducts
Rear:
Hawk HPS (street) / HP+ (track) pads
Vehicle Details:
Engine
PI heads
Comp Valve Springs
HPS intake manifold
Trickflow 75mm TB
BBK CAI
Exhaust
BBK O/R X-pipe
Suspension
Front:
Rear:
Chassis & Weight:
Rear Seat deleted
Mach 460 deleted
Brakes
Front:
Brembo Rotors
Rear:
Here are some detailed pictures of the build-up:
Engine:
Craigslist find - 1997 5.4L from an E350
Tearing it down to the block
Block cleaned up & a fresh coat of paint
Short Block Reassembled
Heads installed
Cams & Timing gear installed & timed in
All installed
Engine:
Heads installed
All installed
awesome buildup!
I almost forgot about the obligitory shots of the "track *****" on track...
Leaving for the track:
Getting ready for a day of racing...
Gingerman Raceway
Grattan Raceway in the wet chasing down a Porsche
Gingerman Raceway
This car is a blast to ride in. So much torque all the time!
Couldnt be owned by a better guy as well.
Thanks for posting it up.
I'm surprised that you went with such relatively low spring rates for a track oriented car. 650#/in up front isn't much stiffer than stock Mach 1/Bullitt.
Nice work man...
Any updates or comments on performance?
If the factory offered the option back in 2000 to get the IRS in a GT I would have done it. Instead I found a local guy with a Cobra that wanted to go drag racing, and I wanted to go road racing. We swapped everything over in my garage in about 3 hours. I love having the IRS. It makes everyday driving much better, and on track, it is awesome. If I kept the SRA I would have gone the route of the MM torque arm and panhard bar. Swapping to the IRS was a lot less work and it has the added bonus of factory durability.
Nice combo.
