Mach 460
Old Jan 7, 2012 | 04:55 PM
benjyc32's Avatar
Mach 460
Have a 2001 with the mach 460 sound system, and it somehow keeps drawing power from my battery and running my car dead because the alternator can't keep up. What can I do to stop it? And what would be the value drop if I put a different receiver in (custom)?
Old Jan 7, 2012 | 05:35 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
How do you know it's the 460?
Old Jan 7, 2012 | 11:19 PM
benjyc32's Avatar
Originally Posted by texastboneking
How for you know it's the 460?
What??
Old Jan 8, 2012 | 12:32 AM
Bear Eats King...
Bear ****s Bone
Fixed
Old Jan 8, 2012 | 05:49 AM
AlsCobra's Avatar
A Man Just Needs Some....
Hey bone. How do I get that little corner speaker off the door? The one by the side view mirror. Can I pull it before the door panel is pulled?
Old Jan 8, 2012 | 08:33 AM
Bear Eats King...
Bear ****s Bone
Honestly I have never pulled mine. Ill get the diagram of of PTS and post it here on the forum so you can see it. Won't be able to till later. Currently not at my laptop
Old Jan 8, 2012 | 08:37 AM
AlsCobra's Avatar
Cool man just wondering. It makes pulling the door panel difficult.
Old Jan 8, 2012 | 08:50 AM
benjyc32's Avatar
Fixed
Because its the stock one that says "Mach 460" on the speakers and tweets
Old Jan 8, 2012 | 08:54 AM
Bear Eats King...
Bear ****s Bone
No! Really!!! I mean how do you know that is what is drawing power?...
Old Jan 8, 2012 | 11:49 AM
benjyc32's Avatar
Ohh sorry, I was trying to multi task.
I pulled the ground cable on my battery and put a check in between it and the ground post on my battery and a current was passing trough it with all accessories turned off and the key out of the ignition.
Then I had that connected still and started pulling fuses in my fuse box and I pulled out a fuse and the light went off. After some research online I found that it was the fuse for my instrument cluster. With the fuse pulled I then put the key in and turned it to the "on" position and see what would still work. The gauges worked still, a/c still worked, but the Mach 460 receiver and my shifter would NOT move.
Old Jan 8, 2012 | 12:01 PM
Bear Eats King...
Bear ****s Bone
Usually the 460 doesn't draw power. Unplug the radio itself and check the draw. Most likely its something else on that circuit.
Old Jan 8, 2012 | 12:15 PM
Scothew's Avatar
Stubborn Bear
TMS Staff
Moving to sn95 forums.
is it possible that a switched accessory wire is grounding out somewhere and causing it to keep part of the 460 system on even with ignition off?
benjyc32's Avatar
I'll give it a whirl and let you know what happens. But with it being my shifter and my stereo, wouldnt the problem be that obviously? I've never messed with a Mach 460 before this so I could very likely be wrong.
Old Jan 8, 2012 | 12:16 PM
Bear Eats King...
Bear ****s Bone
Yes. If a relay is hanging or something it is possible. Buy unusual. I'm betting its something else.
Old Jan 8, 2012 | 12:17 PM
benjyc32's Avatar
No, it's non functional with everything together and no key in the ignition. (if that's what you're asking)
Old Jan 8, 2012 | 12:19 PM
benjyc32's Avatar
I'll check it! I really want to keep original on the inside if at all possible w/o having to get a aftermarket receiver.
Old Jan 8, 2012 | 12:21 PM
Bear Eats King...
Bear ****s Bone
Yeah pull the head unit out and check your draw. There are more devices on that fuse.
Old Jan 8, 2012 | 04:03 PM
benjyc32's Avatar
The draw is coming from my receiver, and one of my amps in the trunk on the passenger side.
Old Jan 8, 2012 | 04:42 PM
Bear Eats King...
Bear ****s Bone
Weird.......
Old Jan 8, 2012 | 05:22 PM
benjyc32's Avatar
Weird.......
Yeah. That's after 2 hours of checking fuses and ground connections. So for now I just have them unplugged. I can't decided about fixing the stock receiver or just get a new aftermarket one.
