Lost about 30miles to a tank
Old Jul 26, 2012 | 09:57 AM
SVTCobraR315's Avatar
I don't know what happened. Maybe it was floridas hot muggy air, or maybe my fuel filter, or maybe a tune is needed... Again. Has anyone lost about 2 mpg randomly? How did you fix it? I know I need to change out my fuel filter. Could that be it? Also when when my car idles it smells very rich. Also my tail pipes are turning black.
Old Jul 27, 2012 | 09:35 AM
Hoss408's Avatar
Losing Two MPG loss does not happen over night, that's approx 10% loss of fuel economy... If you haven't already.. Scan the PCM for DTCs, Do a quick burst down the highway at WOT , if it's a fuel restriction you will notice a lack of power... Though having black smoke and a rich smelling exhaust kind of contradicts a lack of fuel concern. Start with the simple things.. Pull your air filter out and inspect the housing for restriction, fuel system leaks.. Vacuum lines integrity... There could be a numerous amounts of sensors and inputs that can contribute to poor fuel economy.. Ex.-O2 sensor, MAF,ECT, Injectors, A scan and visual inspection is the first critical step. Then we can take it from there. Good Luck!
Old Jul 27, 2012 | 11:03 AM
i ended up blowing my cats out into my mufflers, so i had to hollow out the cats... i have not been tuned since i blew the cats. ive had O2 problems forever. i changed out the sensors and pigtails because it was a shoddy splice job due to LTs, but now... it could be multiple things... i still get the CEL on a daily basis but i figured it wasnt a big deal because of the O2s.
Old Jul 28, 2012 | 12:30 PM
Hoss408's Avatar
So what DTC's are you getting ?
Old Jul 28, 2012 | 12:34 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Rear o2s are not a deal. Front o2s are a big deal
Old Jul 29, 2012 | 01:33 PM
I think they are p133 and p153. They are my O2s on my header collectors (front)
Old Jul 29, 2012 | 11:10 PM
Hoss408's Avatar
P0133-Bank one sensor one slow responding
P0135- Bank one sensor one ckt fault-heater
As mentioned above the bank one and two sensor one... (upstream) sensor are critical for your fuel economy and performance... If they are not able to properly calculate the efficiency of the engine , fuel economy/performance will suffer.
Old Jul 30, 2012 | 06:02 AM
Maaaaaaaaan, I replaced those and the pig tails awhile back...
Old Jul 30, 2012 | 08:07 AM
Hoss408's Avatar
This will help you understand why it's vital...
An Oxygen sensor is a chemical generator. It is constantly making a comparison between the Oxygen inside the exhaust manifold and air outside the engine. If this comparison shows little or no Oxygen in the exhaust manifold, a voltage is generated. The output of the sensor is usually between 0 and 1.1 volts. All spark combustion engines need the proper air fuel ratio to operate correctly. For gasoline this is 14.7 parts of air to one part of fuel. When the engine has more fuel than needed, all available Oxygen is consumed in the cylinder and gasses leaving through the exhaust contain almost no Oxygen. This sends out a voltage greater than 0.45 volts. If the engine is running lean, all fuel is burned, and the extra Oxygen leaves the cylinder and flows into the exhaust. In this case, the sensor voltage goes lower than 0.45 volts. Usually the output range seen seen is 0.2 to 0.7 volts. The sensor does not begin to generate it's full output until it reaches about 600 degrees F. Prior to this time the sensor is not conductive. It is as if the circuit between the sensor and computer is not complete. The mid point is about 0.45 volts. This is neither rich nor lean. A fully warm O2 sensor *will not spend any time at 0.45 volts*. In many cars, the computer sends out a bias voltage of 0.45 through the O2 sensor wire. If the sensor is not warm, or if the circuit is not complete, the computer picks up a steady 0.45 volts. Since the computer knows this is an "illegal" value, it judges the sensor to not be ready. It remains in open loop operation, and uses all sensors except the O2 to determine fuel delivery. Any time an engine is operated in open loop, it runs somewhat rich and makes more exhaust emissions. This translates into lost power, poor fuel economy and air pollution. The O2 sensor is constantly in a state of transition between high and low voltage. Manfucturers call this crossing of the 0.45 volt mark O2 cross counts. The higher the number of O2 cross counts, the better the sensor and other parts of the computer control system are working. It is important to remember that the O2 sensor is comparing the amount of Oxygen inside and outside the engine. If the outside of the sensor should become blocked, or coated with oil, sound insulation, undercoating or antifreeze, (among other things), this comparison is not possible.
Old Jul 30, 2012 | 11:59 AM
Bear Eats King...
Bear ****s Bone
Running long tubes? You need a custom tune for the long tubes do to the fact the are further away from the engine and will respond differently
Old Jul 30, 2012 | 03:22 PM
I've had my car Dyno tuned a few times already. Only thing that changed since my last tune was hollow cats.
Old Jul 30, 2012 | 03:53 PM
Bear Eats King...
Bear ****s Bone
Did he account for the long tubes for shure?
Old Jul 31, 2012 | 05:40 AM
I don't see why not. It was a very reputable speed shop in Virginia. They did a lot of mustangs and track cars.
Old Jul 31, 2012 | 10:58 AM
Bear Eats King...
Bear ****s Bone
Might just need new o2 sensors then.
The slow to respond codes and slow to heat usually mean the o2s were not programmed correctly
Old Aug 13, 2012 | 10:33 AM
Even worse now. 13mpg. I ordered a tune from Steeda. They said they should be able to fix it.
Old Aug 16, 2012 | 06:00 AM
Well got the tune. Now we play the waiting game for results.
unnoticedtrails
Jul 17, 2017 11:10 AM
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
