A little help please?
Old Apr 19, 2012 | 05:13 PM
Quicksilver-4.6's Avatar
So i was checking the fluids today, and thought i might as well check the belts and hoses right?
Well wouldn't you know i need to change out a hose, but the thing is i don't know where in the hell it leads to.Its the house coming out of the back of the throttle body, and leads down into the passenger side fender. Does anyone know what this is by chance? In the pic its the house that is the highest up taped to the other.
Also what is this one with the green cap on it leads to or what it is? (second pic) it seems to be coming out of where the other one is going?
The last pic is inside the fender through the slit between the door when you open it.
Any help would be awesome guys!
Attached Thumbnails A little help please?-2012-04-19-19.01.45.jpg   A little help please?-2012-04-19-19.02.03.jpg   A little help please?-forumrunnerimage.jpg
Old Apr 19, 2012 | 05:19 PM
I can't quite make out the pics, but the bottom one makes me think of heater hose. Smaller than radiator hoses between radiator and block, runs to the firewall to the heater core inside the cab. One in one out that makes a loop - often back to the thermostat housing or thereabouts.
I think that standing hose with the green cap is a/C related.
got access to a repair manual? online or library?
Old Apr 19, 2012 | 05:21 PM
AlsCobra's Avatar
A Man Just Needs Some....
Looks like an evap vapor line. Are the fittings made to the hose ends or are they clamped?
Old Apr 23, 2012 | 05:39 PM
I have access to the internet sometimes, i really just need to buy some manuals.
Well the one with the green cap looks like it has some kind of tap shoved into the hose. No clamps.
The other one slides onto a spout from the back of the tb
Both run inside the fender towards the front of the car
The one coming out the back of the tb is worn out and just bad. I wanted to replace it but didn't know what type hose to replace it with. I know i could get a hose the same diameter but i would like to know just for future reference.
Thanks for the help so far guys!
