How To: Blue LED HVAC and Gauges
Old 8/11/12, 02:40 AM
cntchds's Avatar
I'm not sure you have ever worked too hard on anything.
Old 8/11/12, 04:20 PM
future9er24's Avatar
not a thing, no
Old 12/9/12, 12:25 AM
bluethunderhorse's Avatar
OK I did this mod on my 94 now I will be doing my cobra. I just ordered these
I will get them installed as soon as the bulbs come in, and pix will be posted
Old 12/9/12, 12:46 AM
Location: That town you drive through to get to Myrtle Beach
was it ever decided which bulbs were needed to go into the new edge cars for gauges and HVAC?
Old 12/9/12, 01:39 AM
cntchds's Avatar
The HVAC are the bulbs listed in the article, and I could have sworn I edited the OP with the correct bulb size for the 99-04 Gauges too. I will check..
Edit.
I posted the correct bulb size (74) in the article.
Old 12/13/12, 12:05 PM
cool. That's one of my next projects.
Old 12/13/12, 12:22 PM
shurtual86's Avatar
Check and make sure your gauges have the blue film and not green one. I think 01-04, some had the blue, but most had the green film. Wouldn't want you to buy the LEDs and install them just to find out you don't have the blue film gauges
Old 12/18/12, 09:57 PM
any ideas on how to check that without taking it apart?
Old 12/20/12, 05:58 PM
I'm officially pissed. Mine has the green film.
Old 12/20/12, 06:03 PM
shurtual86's Avatar
That sucks man
Old 12/20/12, 06:19 PM
I'll just get these. Had some like them on my 94 for a long time before the transformer for the lighting in them went out.
http://www.ebay.com/itm/FORD-MUSTANG...741cf6&vxp=mtr
Old 12/20/12, 08:38 PM
****, that sucks. That's the one hesitation I have with doing this project, seems like a hit or miss which led's to buy.
Old 12/20/12, 10:39 PM
From what I've read today 94-00 had the blue film, and all 01-04 had the green film. I may take some 1000 grit sand paper and sand off the green, then color back over it with transparent blue paint.
Old 12/21/12, 12:24 AM
can we get some pics of this when you're working on it?
Old 12/21/12, 02:23 AM
sure
Old 12/21/12, 06:54 AM
shurtual86's Avatar
Edit: If I remember correctly, a few 01-04 came with the blue film ( rare), somebody with a 03 GT was lucky and was able to just do the swap with no problems ( he posted on a thread with a similar write-up on another forum).
There are videos on YouTube that show what you can do if you want to change the color of the gauges. I'll look for the video an post a link when I find it.
Link
Old 12/21/12, 09:35 AM
that looks like an enormous pain in the ***!
Old 12/22/12, 05:19 PM
Ok I didn't take many pictures while doing this, as I was being hounded by my kids the entire time
First and most important drive the car to get the temp to normal, and take pictures of your gauge face while the car is running. After you remove the gauge cluster, take out the T10 torx screws holding the clear lens out, and set the lens aside. Using a kitchen fork remove the needles. Then using something small and flat (I used a 1/2" putty knife), slide it under the gauge face, and work your way around to lift off the face. Now get some 200 grit sand paper, and gently sand off the green film from the back side of the gauge face. Be careful not to get the red parts.
Should look something like this
Tape off the warning lights and the red areas of the gauge face, then spray some duplicolor adhesion promoter followed by blue Duplicolor Metal Cast over the entire backside. The metal cast is a transparent paint.
Let that dry then spray plain white over just the areas you want to be blue
After that drys remove the tape,and lay the face back onto the cluster, and turn on your lights
Drive the car again to get it back up to temp, refer to your pictures you took earlier and reinstall the needles while the car is running (don't push them all the way down, or they will not move). Now you can put the lens back on, bolt the cluster into place and install your trim. Enjoy
Old 12/22/12, 06:14 PM
shurtual86's Avatar
which LEDs did you get?
Old 12/22/12, 06:24 PM
  #40
that looks great. its killing me, do I put up with the pain and do it, or not? haha
Quick Reply: How To: Blue LED HVAC and Gauges
