High/low beam at same time
Bow Chica Bow Wow
TMS Staff
TMS Staff
Ok mustang faithful...q/a time
Has anyone modded thier SN95 headlights so the low beam is on all the time when the headlights are on. Basically so when you have your highs on the lows are on as well just like when you pull the stalk back to "flash" someone?
If so was it hard was there any side effacts like too much heat build up in the bucket or maybe burned up wires or perhaps shorter bulb life?
Needs to be more Astony
I have no idea how you would do it, but wonder why you would want to doug.
Seems like it might make too much heat.
My wife has a mazda cx7 and her tail light bulb melted a hole inside the housing...so I know the lights can get extremely hot and would be moreso if both were going.
as far as the how.. its probably not to hard to wire in a switch that uses the "pulling the stalk back flash" function, just gotta trace the wires or find a diagram and put in a switch that keeps the circuit closed rather than just bouncing back with the stalk.
As far as heat, I have no real knowledge there, but dooes anyone know if there are LED kits to replace the bulbs? I thought about mostly from a "more light" perspective, but if thats an option, it could dramatically reduce the heat in the housing. Prob not necessary all the time, but might be helpful in this situation.
Whats the reason? I too am not sure why
Bow Chica Bow Wow
TMS Staff
TMS Staff
As to why..when you have your high beams on the light actualy is effective from about 25 ft from the front of the bumper out..with low beams being from the bumper to about 25ft BUT with a very wide patter. the high is a long narrow pattern so combine these two and it's a brighter view and easier to see deer at all times. Where I live it's deer central here.
I really do not think it would be difficult at all. What I would do is just clip the wire from the positive side on the switch to push back the stalk and use a T-connector to connect it in with the switch for pulling the stalk. Like stated above, the lights can get very hot, but I'm not sure how much hotter they are in that position, nor the temperature they can withstand.
Bow Chica Bow Wow
TMS Staff
TMS Staff
no teh high low is the same bulb. They are a 9007 double filament bulb. I beleive they are single positive for each filament and a common ground.
My SN95 is low too. Tundras are the worst! Their headlights are pretty much perfectly angled right into the windshield/rear view mirror. Still don't care. I just look away....
So maybe they like haha lets aim these right at him!
Just to quell the curiosity about how to do it. Take a relay and connect it to your headlight harness. Power in wire would come from the high beam wire, power out to the low beam wire, and the activation wire would also come from the high beam wire. Having the relay in there would keep the high beams from coming on when you just have the lows on.
roushcollection
7/28/15 02:08 PM
