help pls
help pls
I just bought a 04 gt it has long tube headers full exhaust looks 2 1/2 all the way has after market cold air and a Bama tuner. The car runs a little ruff. Going to change plugs and wires. Notice the car uses a lot of fuel and even black smokes when you get on it i don't know how to use a tuner but wanting to put a tune up on it and put it back to factory tune are what ever someone can recommend me any info would help out alot thanks. I filled up last night and turn the odometer to trip I have only been 35 miles and the gauge already reads about have a tank you can watch the needle move
Make sure the fill neck to the fuel tank is still sealed well. It's common for these 94-04 Mustangs to have gas leaks there. The rubber seal that connects the filler neck to the gas tank is usually rotting away and letting the fuel evaporate.
Also, if you enroll yourself into our Free Tunes for Life program, the Bama Team and send you out a fresh set of custom tunes. They'll also be able to look at your datalogs and see if your fuel trims are dialed in. This could help diagnose your fuel issue!
Shane
Shane
If you can tell what vents work and what ones don't work, it may help you narrow down where to start looking. Either way, it all leads back to the HV/AC unit behind the dash.
Shane
I wish you the best of luck though!
Shane
Pull out the blower motor and check to make sure there isn't a mouse nest or something stupid sitting on top the where the blower motor sits in there blocking all the air flow. Might not be but at least it's easy to check before pulling the dash
Ok pulled the blower motor out and found that there was a square piece sitting on top of it i am guessing that it the door that opens for air to come from outside the car guess it broke off and feel on top of it. I moved it back and a/c blows hard and cold thanks for the help only got one problem left and that's to get it tuned because I can't figure out this bama tuner I can change to the 87 or 91 93 and it runs good for a little then goes back to running ruff
Nighthawk13
662
Jul 9, 2017 04:23 PM
LEO_06GT
05-09 Interior and Audio Mods
48
Jul 21, 2006 12:54 PM
