cold air induction?
What 99Pony said. A lot of guys say they "feel" it, but if I spend 150+ on a mod, the weight reduction in your wallet is going to influence me quite a bit...
Installed a K&N on my supercharged 95 thunderbird and my Dad's 02 F-150 and had noticeable gains on both vehicles. My Cobra came with it already on so I can't speak to that difference. If it was me I'd do it.
Well if you get a cold air your not gonna notice much initially because your cars computer is programmed to let certain amounts into the engine. Invest in a tuner like the SCT tuner or Duablosport and youll definitely notice your pony buckin! Check out americanmuscle.com for more details!
I ended up getting one and im glass I did. The factory air box had been put together with silicone. It definitely idles better then before but I also cleaned the maf sensor and throttle body.
Do yal think that if after you put in the cai you relearn the computer like you would when you clean the throttle body it would adjust itself over time to the new amount of air an run better? Just a thought
Cobiecane
Oct 23, 2015 08:44 AM
