Broken key....
Old Nov 14, 2012 | 11:54 AM
Barricade's Avatar
Broken key....
Ok...long story short one of the keys on the Mach1 got bent & subsequently it broke.
The transponder is fine though.
Bought a new key but the instructions require both keys TURNING in the ignition
to program the transponder.
Am I screwed?
Dont really want to get sexually assaulted by a dealership....
Old Nov 14, 2012 | 04:22 PM
yep, unfortunately you are. Once you have two keys, you can program as many as you want, but with only one, they have to do the second key.
Old Nov 14, 2012 | 05:36 PM
Dbranham's Avatar
When I got my car it only came with one key/chipped , and one fob. I got a second key made and programmed at a hardware store an bought another fob and now have to complete sets unless it changed from 96
Old Nov 14, 2012 | 06:54 PM
I'm almost certain it did. We bought my sister an 04, it only came with one key, and we had to have a dealership program the other.
Old Nov 14, 2012 | 07:08 PM
Skylar's Avatar
My '04 only came with one key and I got ACE Hardware to make a copy of it. About half a year later the chip in the replacement went bad and wouldn't crank the car. I took it back and they replaced it for free.
Old Nov 15, 2012 | 05:25 AM
Dbranham's Avatar
Skylar does your key match the original? As in is it a ford key or the kind ace has? Maybe that is why we could do it and he can't.
Op did you buy a ford key?
Old Nov 15, 2012 | 07:33 AM
Skylar's Avatar
It's the kind Ace has.
Old Nov 15, 2012 | 09:55 AM
dleblancbu's Avatar
Am I screwed?
I have a 2013 GT, and had a hardware store make a third key. Cost about $75, and is just a key with a chip, no buttons like the original, but works fine. Took them about three minutes to do using ONE of my original keys.
Old Nov 15, 2012 | 10:01 AM
Knight's Avatar
Needs to be more Astony
Am I screwed?
Can't you just hold the broken keys transponder next to the new key to be used like the second key? Its all wireless transmitting, so it doesn't know the metal end in the ignition is not attach to that transponder.
Old Nov 19, 2012 | 05:31 PM
Torrbo916's Avatar
Or even have a door key made an use the old transponder chip to " make" another key.
GTown3r
1994-2004 V-8
Aug 30, 2015 08:04 AM
Stephanie Blaker
Aug 25, 2015 07:36 PM
