Battery Shutoff Switch?
Old Jun 27, 2010 | 05:09 PM
cntchds's Avatar
Which one did you decide to go with?
Old Jun 27, 2010 | 07:08 PM
harristotle's Avatar
Went with this, http://www.summitracing.com/parts/PRF-30204/?rtype=10 because I don't really need the emergency push button or remote, just want to be able to hop in, flip a switch and go. There's already a hole in the dash right by my headlight **** so I will most likely just use that existing hole to mount the switch.
Old Jun 28, 2010 | 10:00 AM
yeahyouknwit's Avatar
I had the same problem with mine draining. Mine was simple and stupid. I had pulled the fuse for my interior light because they would always stay on. My fiance drove my car one week while heres was in the shop and turned the headlight **** to the on position for the interior lights. Since I pulled the fuse I had no idea that the **** was on and it was always pulling from the battery. Wish yours was that simple but at least you have found a way to fix it.
Old Jun 28, 2010 | 10:04 AM
I'm hoping it still turns out to be that simple although I doubt it with what I've tested so far, but for now this will be a welcome solution. We don't have access to garages here so I keep her covered religiously. It will be nice to go down to the car and not have to pop the hood before I can head out.
Old Jun 28, 2010 | 11:53 AM
cntchds's Avatar
The bad part is going to be that it won't keep the time, or your radio stations set.
Old Jun 28, 2010 | 01:25 PM
Yes, but I unhook the battery every time I park it so it does that anyways. I figure getting to drive a Cobra vert is worth not having the correct time and radio stations
Old Jun 28, 2010 | 01:36 PM
Radio delete
Old Jun 29, 2010 | 11:31 AM
Picked up the switch today, planning the install tomorrow... except I'm afraid I might have found a problem. The positive terminal (the one the kit is required to hook up to) has 2 sizable wires going to it, but the kit is setup to have 1 wire go into it and 1 wire go out of it. Should I send the 2 into the solenoid, then just buy battery cable to go from the solenoid to the battery?
I really hate electrical stuff!!!
Old Jun 30, 2010 | 09:30 PM
Put it in today. I will probably make a separate thread with the pics and progression of the installation. Painless performance... very applicable to the function of the mechanism, not so much to the installation lol. I am certainly happy with it so far though.
Old Jul 17, 2010 | 08:50 PM
Just wanted to say that after a couple weeks of use I am still VERY happy with the switch, still functioning as intended!
Old Jul 18, 2010 | 12:02 AM
WaltM's Avatar
Very good. It's a shame you couldn't track down track down the problem, but at least you have this as a workaround!
Old Jul 18, 2010 | 10:20 AM
Who knows... I'm saving my money for a Shelby in the next 1-2 years, and it drives me nuts not working on her besides to clean her up and keep her nice so I may still go back and continue to search for it.
Old Jul 21, 2010 | 05:04 AM
90fox's Avatar
Hey sorry to threadjack, but I just joined this forum and apparently I can't send private messages. Maybe I have to have a certain post count or the mods haven't enabled this function.
Either way I have been wanting to install a hurst shifter handle like the one you have recently installed. The pictures you posted in the thread you started about it show that your using your stock shifter boot.
Is this correct? I wanted to buy the handle but was afraid the leather shifter boot wouldn't slide down the shifter handle far enough to allow the hurst name to be seen. Did you modify your boot? Could you tell me where you got your handle?
Thanks I appreciate any help.
Again sorry for the thread jack. Maybe I'm stupid and missed seeing a private message box.
Old Jul 21, 2010 | 08:16 AM
No need to apologize, I don't mind.
I have a steeda tri-ax short throw shifter. The Hurst stick bolted right to it.
The stock boot likes to slide up on the shifter, but not to the point that it looks bad. I usually just push the boot down and it stays pretty low for the most part. I've enjoyed both the look and function of it.
The first picture was actually a while after I installed it. My friend broke my tranny, (there's a thread on that if you are curious of the story), and when we had everything apart I took the time to clean up the short throw unit. Hope this helps!
Old Jul 21, 2010 | 03:16 PM
90fox's Avatar
Cool. Thanks for the pics.
I'm just mainly concerned with the shifter boot. I didn't want to use those 60's style pleated ones. I found a smaller stock looking leather shift boot from roush that would work great with this shifter stick but it seems it's only in dark charcoal not black leather.
Here's a thread with the pic for that roush boot. Hard to see it though.
http://www.lonestarstangs.com/forum/...ter-35978.html
Could you tell me where I can find just the shifter stick? I can only find the whole hurst short throw kit.
Old Jul 21, 2010 | 03:30 PM
WaltM's Avatar
Could you tell me where I can find just the shifter stick? I can only find the whole hurst short throw kit....
You could go with this...
http://www.jegs.com/i/Hurst/530/538-0036/10002/-1
Old Jul 21, 2010 | 03:31 PM
I don't see a link. I got my shifter off of ebay, I'll see if I can find one right now. It was like 70 bucks for just the shifter I think, and it took a while of searching to find a white one as most were black or the shorter stick if memory serves correct.
Old Jul 21, 2010 | 03:33 PM
90fox, as long as your avatar is what it says, that is exactly what you need.
Old Jul 21, 2010 | 03:58 PM
90fox's Avatar
Hey sorry, I edited my post above with the link. I forgot to add it haha
No I this is going in a 96 with a t-45 trans. I don't like that pleated shifter boot either in the link listed. That's why when I seen your picture and you used the stock shifter boot I had to find out if you modified it. So it's good to know I can use the stock boot.
It seems that all the hurst chrome shift sticks come with holes spaced 7/8" center-to-center with 3/8" bolt size. I think this should fit our stock shifters etc.
Here is the one I want: http://www.jegs.com/i/Hurst/530/538-4106/10002/-1
I want to use a different shift **** but hurst shift sticks come with a 3/8"-16 thread for the shift ****. The **** I want to use is 12mmX1.25 . Maybe I have to drill the shift **** and helicoil it. The shift **** I want is for a 05-10 mustang.
Does anyone know of adapters to make different shift ***** fit on different thread sizes?
Old Jul 21, 2010 | 04:16 PM
  #40
I see the link now lol.
I found what I'm pretty sure is the lever I've got. I would PM you, but you need more posts... so keep posting or let me know if you don't mind me posting the link in this thread.
I don't know about an adapter for the **** though...
