99 GT cluster sweeps / batt ?
Old Jul 5, 2005 | 05:43 PM
av99gt's Avatar
On my 99 GT I have recently noticed that the cluster will sweep all the needles when I start the car.
Seems to only do it when the car hasn't been started for a while. After a 20 minute drive if I shut the car off and start it again it does not sweep.
Is the battery going south? It is the original 6 year old battery (57K) the eye looks like a bright yellow it maybe green though. Using the HEC cluster test mode the batt reads 150 with the car off.
Old Jul 6, 2005 | 01:38 PM
jgsmuzzy's Avatar
Definately the battery, happened to mine as well. Get the alternator checked as well. Basically, when you start the car, the starter uses ALL the power available in a dying battery. When the starter disengages, the comp gets power back and thinks it has been disconnected, hence the reset (sweeping) of the gauges.
HTH
J
Old Jul 6, 2005 | 03:18 PM
av99gt's Avatar
Thanks!
Ecostang
Nov 3, 2022 08:50 PM
samjluck
Sep 17, 2015 10:24 PM
Grabber5.00
Sep 13, 2015 06:53 AM
