96 cobra info
Old Apr 18, 2014 | 05:00 PM
jay4011's Avatar
96 cobra info
I am needing some help. I bought a 96 cobra with 22k miles on it wrecked it is a hardtop, I am going to get a donor car and would like to get a convertible and transfer everything from the cobra to the convertible, does anyone know if the donor can be a v6 gt or cobra car. I am going to completely strip the donor buy both cobra bumpers and cobra hood have the car painted and put it back together with the cobra thanks .
Old Apr 18, 2014 | 06:50 PM
The Mad Dooby's Avatar
Doesn't matter what donor car you get. The K-member and rear end from the cobra will bolt in to where the V6 K-member was.
Old May 7, 2014 | 08:41 PM
Mystic_Cobra's Avatar
I've done this before so I can give you a few pointers...
I had (have) a 96 Cobra (mystic) that I wrecked. I rebuilt the car with a donor body.
The first deal I found was on a 96 GT Auto without PATS.
1. Auto vs manual - get manual if you can. The shifter hole is a little different, IIRC. Required some trimming.
2. Crossmember - There was a strange mid year change of cross member mounting locations that is related to the transmission tail shaft housing. Ford made two different versions for a while. GT and Cobra were different. At some point, they made a change and both were then the same. I had to cut the spot welded trans cross member brackets from the new body and install a Cobra bolt in crossmember. I also had to swap tail shafts. Check this out ahead of time and save some work.
3. Wiring - The donor car did not have PATS, my Cobra obviously did. The body harnesses are all different. The car wouldn't run without PATS. I had to transfer every harness from my wrecked Cobra to the new body (all the way to the tail lights).
That's all I can think of now. Look for 96-98. Pre-96 had different spindles, different K-member, and a few other things, I think.
Let me know if you have more questions. It's been a few years and that's all I can remember now.
Autotooner
Nov 24, 2017 12:42 PM
blackhawkkid308
1994-2004 V-8
18
Dec 22, 2015 03:17 AM
trackpack13gt
Oct 2, 2015 08:20 PM
blackhawkkid308
Sep 30, 2015 04:04 PM
Ray11
Sep 25, 2015 12:43 PM
