350 to the rear wheels
Old May 5, 2011 | 09:07 PM
sinisterbullitt's Avatar
Is anyone there? What mods power wise an strength/safety wise. 350 to the wheels is about 400 to the crank right? Is it possible n/a. Any help,parts lists,experiences (good or bad) thanks guys
Old May 5, 2011 | 09:11 PM
Hawaii 5.0's Avatar
Hmm, i suppose full exhast, intake manifold, full intake system, cams, tune? Thats about all im guessin, n/a that is. If you want those numbers just get a vortech with 9 psi boost pr a KB conv. runnin same boost. Internals should be fine with these applications
Old May 5, 2011 | 09:20 PM
I want basically the most power I can get n/a while having a sturdy happy DD. What's about the Max from a built n/a 2v 4.6 you think?
Old May 6, 2011 | 05:36 AM
Onesickstang01's Avatar
350 wheel is going to be pretty hard to get with just bolt ons. If you can do it you will spend much more than just putting a vortech on it
Old May 6, 2011 | 05:41 AM
Evil_Capri's Avatar
You can always take weight off the car to obtain a better power/weight ratio . . .
Old May 6, 2011 | 07:53 AM
OK so if a stock bullitt has 265 HP that's what 240 to the rear wheels
Old May 8, 2011 | 02:14 AM
cntchds's Avatar
Much better choice than going for a hp goal.
Old May 8, 2011 | 03:55 AM
Hawaii 5.0's Avatar
^agreed
Having bout 300hp but less weight will feel the same as havin 350. Get lighter seats (corbeau or sparco are more affordable and do a good job) lighter rims, Delete the rear seats, Lotta stuff like that. The wheels will make the biggest difference due to unsprung weight.
