150K miles, feels sluggish....what to do?
Old Nov 22, 2008 | 06:54 PM
UMich97's Avatar
Hey everyone, just wondered if anyone had any ideas on what to do to restore some of the performance from it's younger days. I know she needs new shocks and struts, but thinking more in lines with what to do about the general sluggishness. She's just not as quick as she was when she was younger. Any suggestions?
Old Nov 22, 2008 | 07:11 PM
codeman94's Avatar
plugs and wires....tune up should help
Old Nov 22, 2008 | 07:43 PM
UMich97's Avatar
Good idea codeman.....I did the plugs about 25K ago, but didn't do the wires. Do you know if there are any good write ups on doing the wires for a V6? My goal is to do all of my maintenance and mods myself......well, the ones that make sense to do at home.
.....and since the plugs are so cheap, I may even add new ones again. Do you think any one type of plug or wires are better than another?
Old Nov 22, 2008 | 10:52 PM
1999Pony's Avatar
Just do a full tune up. You should get alot of that performance back.
Old Nov 23, 2008 | 06:18 AM
do a compression check just to see if everything is ok in there
Old Nov 23, 2008 | 01:32 PM
UMich97's Avatar
When you say full tune up.....what would that entail. I had asked my dealer about a tune up at 100K and they just seemed to be like "well, what do you want us to do?".
UMich97's Avatar
Glenn,
Maybe I'm a bit of a newb, but how do you do the compression check?
Old Nov 23, 2008 | 01:35 PM
conv_stang's Avatar
Plugs, Wires, Coil Packs.
Old Nov 23, 2008 | 02:55 PM
In_A_Roush's Avatar
FUEL PUMP FOR SURE!
Old Nov 23, 2008 | 03:10 PM
1 COBRA's Avatar
Originally Posted by UMich97
... She's just not as quick as she was when she was younger.
In all likelihood, neither are you.
Old Nov 23, 2008 | 03:24 PM
conv_stang's Avatar
HAHA thats too funny! I'm not as good as I once was. But I was good once, as I ever was!
Old Nov 23, 2008 | 07:41 PM
steve-o's Avatar
OH BOY HERE WE GO AGAIN...
Old Nov 23, 2008 | 08:47 PM
UMich97's Avatar
Oh, so very true. Haha.....maybe the only "sluggishness" is the 20 lbs I've gained over the last 10 years.
.....sounds like wires are a definite one and I'll take a look at the coil pack and fuel pump too. ....that is, if they won't set me back too far and I can do the install myself. Otherwise, I may have to wait a while.
Old Nov 24, 2008 | 06:16 AM
Originally Posted by In_A_Roush
FUEL PUMP FOR SURE!
why?
Old Nov 24, 2008 | 06:21 AM
Glenn,
This guy is doing a compression test. He is holding a compression tester. Pull all plugs screw the tester in and then turn the engine over a few times. Write the results from the tester down. Test each cylinder. There should be less than 10% difference between the results for each cylinder.
Old Nov 24, 2008 | 10:15 AM
when you replace the wires, make sure you only do one at a time, so you dont get one backwards
Old Nov 24, 2008 | 02:08 PM
conv_stang's Avatar
150k just go ahead and do the V8 swap : ) you can prob rent a compression tester from like autozone or advance auto.
Old Nov 27, 2008 | 06:15 AM
edumspeed's Avatar
Legacy TMS Member Pr
Change your plug wires if you don't remember the last time you changed them. Also, change your fuel filter too.
Old Dec 1, 2008 | 01:44 AM
chris8519's Avatar
My dad is a mechanic and he HATES those fuel additives by STP and Mobil 1, etc.
He used to use them (ironically, on his 66 GT) and when he rebuilt it, there was a weird chemical burn mark on each piston head. He swears it was because of the additives. And there is reason to trust him.
BUT.
I use those things religiously (and hide the evidence... seriously...). I have a 2000 v-6 with 112k miles, he has a 2001 v-6 with 120k (driven MUCH lighter than mine). I recently took his to work; the engine has that sluggish feeling you are probably talking about.
He keeps his engine tuned up as much as mine; the only real difference is the use of those fuel system cleaner additives that I use; I notice the effects every time I use it.
Also, I use the high mileage Valvoline 5-30 synthetic while my father uses the same 'ol by-the-book Motorcraft. Might have something to do with it.
Old Dec 1, 2008 | 07:14 PM
2003REDGT's Avatar
SEAFOAM!
