Woodview Dash Trim or Other
The Analog Admin!
Received 3,193 Likes
I realize the aftermarket Dash Trim has been Talked to death but I have a few questions I would like to ask for those who Actually Have Purchased and installed one of these kits!
I have a non IUP car That I am upgrading. I will be installing the IUP steering wheel and I want the Finish that Matches the Steering Wheel the closest.Is it the nickel or the brushed finish? I do NOT want to match the factory IUP style dash.
Also for those who have installed the kits are you happy with the results? Were there any problems? Is there a better kit out there? I will be doing the Dash Area where the factory IUP was installed only. Also what did you Pay for Kit?
KC
KC
I'd say the IUP steering wheel is more "satin-nickel-type" (it's basically plastic with a satin nickel-type finish, like the door handles and the top of the manual shifter). The silver on the steering wheel doesn't really match the aliminum dash trim anyway (aluminum dash trim has vertical stripes cut into it, and is actually aluminum).
Anyway, hope this helps a little, but if you want to match the IUP steering wheel you should probably lean towards satin nickel in other places as well.
9/16/15 06:44 PM
