VSS Wire
Old Dec 20, 2005 | 10:49 AM
SurfnSoCal's Avatar
I searched here for info on the VSS wire, but I got conflicting results. Some threads said the wire isn't there at all...and others said it isn't needed. But then another one said you HAVE to hook it up, as did the instruction manual for my nav (Alpine NVE-N872A).
Does anyone have an absolute answer on this?
Old Dec 20, 2005 | 11:24 AM
withinavoid's Avatar
From what I understand, you don't have to hook it up. If you leave it off you will not get as accurate results supposedly. I went ahead and hooked mine up and it's been working great for me but I also did the bypass on my AVIC-D1 so I could use it while moving.
Checkout Hawgman's post on the VSS wire.
Old Dec 20, 2005 | 11:49 AM
groupset's Avatar
The VSS wire *is* absolutely on the '05 Mustang GT (and I presume it's in same location on the '06), but no; you don't *have* to hook it up. (At least you don't on the AVIC-D1; ymmv with any other unit.) I tried my AVIC-D1 both with and without the VSS; I like it with VSS better - just seems to show a more accurate fix. And I, like withinavoid, also did the bypass on my AVIC-D1 - now works like it should have out of the factory.
Old Dec 20, 2005 | 11:54 AM
SurfnSoCal's Avatar
so its just a matter of splicing the vss wire from the nav into the wire on the PCM box?
Old Dec 21, 2005 | 11:08 AM
SurfnSoCal's Avatar
update-
on the 12volt forum, a guy replied to this same question-
"Good Evening SURFNSOCAL,
Unfortunately your vehicle has no VSS.they have OSS(Output Shaft Speed)only.here is solution:
1 no hook up VSS,then wait for CAN-BUS interface from Soundgate or similar mfg. 2 use API(analog to pulse interface) from Beijer Automotive from Neitherland then convert OSS to VSS. Some one try to hook up OSS from this vehicle's PCM(Powertrain Control Module),But We never do this.We think this may cause the damage of transmission or PCM. If you want to try OSS picking up, use diode just in case.
Good Luck! Happy Holidays"
(he's from Japan)
Does this make sense?
Old Dec 21, 2005 | 12:10 PM
hawgman's Avatar
Correct... The 05's no longer have VSS, it is OSS. PCM reads the OSS and makes up its own VSS inside of the PCM, so its electronic. You can read it with a scan tool and bring up the VSS pid.
If you do not hook it up, you will not get an accurate location on your GPS, and depending on the GPS it will not give you your accurate speed, or destination arrival time.
If you want to hook up the wire, hook it up here.
[attachmentid=41247]
Old Dec 21, 2005 | 12:16 PM
SurfnSoCal's Avatar
alright Doc, I trust ya. But that guy scared me with saying if I hooked it up via the PCM...I could damage stuff.
Old Dec 21, 2005 | 12:33 PM
hawgman's Avatar
Well, technically he is correct. There is a chance that something could be damaged by hooking it up. There is a chance that you could damage something slamming your hood too hard. He is just covering his butt in case you happen to hook up to the wrong wire, or somehow ground the wire and start the car, or whatever, and then try to come back on him and say that he told you to hook it up.
Come to think of it.... *Disclaimer- There is the outside chance of possibly damaging your electrical system, your navigation system, or your PCM by improperly hooking up this wire. I take no responisbility of damages should this occur.
It's all cool man. Many people out there running navigation systems with the OSS wire connected to the VCC wire on the navigation unit.
Old Dec 21, 2005 | 12:37 PM
SurfnSoCal's Avatar
alright....do I splice it in before it goes in the PCM....or directly where it connects to the PCM? ex. back on the wire...or at the end?
Old Dec 21, 2005 | 02:31 PM
hawgman's Avatar
I spliced mine close to the plug. It needs to be near the plug and not down in the harness. In fact, my spice is close enough that the plug cover actually covers the splice up.
Old Dec 27, 2005 | 12:34 PM
SurfnSoCal's Avatar
ok how did you run the wire from the trunk/cabin in to the engine bay...
Old Dec 27, 2005 | 02:19 PM
groupset's Avatar
I took off the passenger side wheel, then removed the inner liner (towards the rear of the wheelwell). This exposes the routing for the radio antenna, which passes through the firewall directly into the passenger compartment. Easy enough to punch a little hole in the grommet around that antenna and then thread your VSS wire through and into the engine compartment from there.
Old Dec 27, 2005 | 02:27 PM
SurfnSoCal's Avatar
darn. I hooked up the VSS wire off my nav and spliced it it in to the wire shown in that picture. still says the VSS wire is not connected on the nav screen. I discconnected the battery to see if I can reset things. I hope that works.
Old Dec 27, 2005 | 02:54 PM
SurfnSoCal's Avatar
ok hooked it up, and got really crazy numbers (CURRENT SPEED 1237MPH) and my position is still off by 100ft. not sure what to try now.
anyone? help!
Old Dec 27, 2005 | 05:00 PM
Redfire05GT's Avatar
I met a 2005 vert owner that had a system, with GPS installed. He told me that the installer went with a connection to the ABS at the rear wheels. 2005 do not have a VSS. As for the PCM module, I would stay away from that. He has had it installed for over 5 months now and he has not said anything about any trouble via the ABS. I am not a mechanic so can't tell you more, but I would bet it would have something to do with the traction control system since that works in conjunction with the ABS. Might be worth a check out.
Old Dec 27, 2005 | 05:09 PM
SurfnSoCal's Avatar
interesting...I wouldn't even know where to look for that. but thats another option I can search for...
Old Dec 27, 2005 | 07:57 PM
hawgman's Avatar
Trust me, the OSS wire for a VSS signal is what he wants and it is not going to damage the PCM to splice to that wire. Provided he does not screw up the splice and ground it somehow.
Old Dec 27, 2005 | 08:00 PM
hawgman's Avatar
anyone? help!
As stated in the PM, my vehicle sensor speed was all kinds of jacked for the first day. It said I was doing 180 down my driveway!. Next day, everything was normal.
As for the positioning, that is going to boil down to your GPS itself and how it interacts with the satellite. When I mentioned earlier on in the thread about positioning, I meant the GPS's ability to determin your speed and destination arrival time, not how many feet you actually are from where the GPS says you are. The OSS signal from the car is not going to have anything to do with that.
Old Dec 27, 2005 | 08:06 PM
SurfnSoCal's Avatar
ok, I will re-hook up the OSS to VSS wire and try driving with it for a day. let you know tomorrow.
thanks Doc!
Old Dec 27, 2005 | 09:19 PM
hawgman's Avatar
No problem man.
Gotta admit, it does look cool to be going that fast
Mar 30, 2021 09:29 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
mx5jhb
Sep 30, 2015 04:44 PM
Sep 23, 2015 03:21 PM
