Standard Shaker 500 question
Old Nov 7, 2008 | 03:46 PM
Twin Turbo's Avatar
Post Standard Shaker 500 question
Hi all
Not a modification question I know, but......
I have a standard Shaker 500 in my car. Now, if the stereo is on and I remove the key from the ignition, the stereo turns off immediately.
I'm told that on most S197s, the stereo should stay on for 10 minutes after the ignition is switched off, or the drivers door is opened.
Is there a way to switch between the two settings??
Cheers
Paul
Old Nov 7, 2008 | 04:13 PM
ronslakie's Avatar
I have an 07 GT and the radio stays for 10 minutes or until either door is open. I did not see anything in the owners manual that indicates that this can be changed. I'll check out the shop manual tomorrow and see if there is any info in there on this.
Ron
Old Nov 7, 2008 | 04:20 PM
Twin Turbo's Avatar
Many thanks, I appreciate that.
Old Nov 7, 2008 | 04:23 PM
Doogie's Avatar
susbscribing as this has my interest
Old Nov 7, 2008 | 05:07 PM
topbliss's Avatar
as far as I know its a standard feature that cannot be tunred off. hmmm
Old Nov 7, 2008 | 06:08 PM
Same here. When I had it. As a matter of fact all three of my Fords do the same thing. Radio stays on till you open the door. I have never seen anything about being able to turn this function off.
Old Nov 7, 2008 | 11:37 PM
houtex's Avatar
Correct me if I'm wrong, but does not everyone's map lights come on when the key is removed, but the doors are still closed? Mine do. I kinda found that odd... Radio *does* stay on.
I wuz thinkin'... maybe it's a cross connect/short/brain fart on the car's part, but could that little feature could be what's causing it? Just throwin' that one out there.
Old Nov 8, 2008 | 06:03 AM
Twin Turbo's Avatar
The main reason I'm asking is because I've had a couple of flat batteries. I know leaving the stereo on before switching off can sometime kill the battery.
Old Nov 11, 2008 | 07:22 PM
Infinity's Avatar
Did you buy the car new?
Old Nov 12, 2008 | 02:07 PM
Twin Turbo's Avatar
No, the car was bought by a US serviceman stationed in the UK. I bought it from him just over a year ago.
May be my car is unique
Old Nov 12, 2008 | 07:09 PM
ds63's Avatar
Radio stays on for ten minutes unless a door is opened. I know this from waiting for the school bus every morning. Map lights also come on when key is removed...
Old Nov 13, 2008 | 05:59 PM
Cavero's Avatar
This doesn't have anything to do with the actual radio itself. I've got an aftermarket head unit and it'll still stay on for 10 min after taking the key out of the ignition, just like the Skipper 500. I wish I could tell you more about it, but its been a while since' i've read about it. My guess is the car just cuts the voltage to the RUN wire, telling the radio to turn off, the same way it stops the windows from working after either 10 min or when you open the door.
Old Nov 13, 2008 | 06:00 PM
Cavero is right. I forgot to mention I have aftermarket and it does the same thing as when it was stock.
Old Nov 13, 2008 | 09:25 PM
Cavero's Avatar
course i am
Old Nov 15, 2008 | 02:57 AM
Infinity's Avatar
Not necessarily. If the radio has been wired wrong, it can show these problems. Pull the radio and see if it it using the factory harnesses or if it has been hacked at some point. There's dual power wires and if they're switched, everything will work fine, but won't give you the time after key off. There's also the possibility one of the fuses is gone- do interior lights and such stay on until you open the door?
duppycat
Feb 16, 2019 08:36 AM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
