Speaker wiring
Anyone know where to get the wiring diagram or atleast the + and - for the rear deck speakers? Can't tell from the old speaker. Thanks for any help you can give.
Sorry should have posted in the audio interior mod page.
Here's a tip for you to check speaker polarity. Get a 1.5 volt battery, (no more), a friend, and a couple pieces of speaker wire. Hook up the 2 pieces of speaker wire to the + and - tabs of the speaker. Take the other ends of the speaker wire to the battery. Hold the - lead from the speaker to the - end of the battery. Touch the + lead to the + end of the battery. Have your friend watch the speaker while you touch the battery for 1 second (no more). If the speaker pops out, then the + is the wire touching the + end of the battery and vice-versa. If the speaker pops in, then the + is the end touching the - side of the battery. DON'T do this with tweeters. You'll ruin them.
Edit: Disconnect the speaker from your cars wiring and only touch the speaker. After this you should be able to figure the wiring out.
