Secret menu OEM Navigation menu pallet colors
Tms Mustang Member ------ The Customizer!
This is a total shot in the dark but I was finally able to get into the secret menu in the OEM Navigation unit and one of the menu items is that you can change the color pallet of the main menu among other items.
This option has 274 Index options (for example Index 25 is the background) that you can change.
So would anyone know where I can find a list of what all 274 indexes are because I want to customize my menu colours to look a little more modern.
John. Have you tried this site?
http://www.freefordradiocode.co.uk/
Here is what Sonya looks like after a 375 mile (750 total) run to Fairbanks this past weekend. I had so much fun running thru the mountains around Denali. Killer drive.
Thanks for the help but I just figured out that the unit head doesnt remember anything you program or change into it after you turn off the car! Totally sucks!
How is that possible? I've read that a lot of ppl have the same issue that when changing something in the developers menu that it doesn't save like for example the gps restrictions. What could possibly be attached wrongly? Everything is plugged into the right spot.
Do you have an OEM nav unit? Maybe you can try and show me that yours works after changing a colour of the menu, turning off the car, then turning it back on to see of the change remains.
My bad if I assumed the guys that developed the unit are weren't knuckleheads. That just seems stupid.
John, do you remember when Jim, 408Stang and Data174 were talking about making the changes inside the head? The IDS was required to make those changes and make them stick. If it was just done with the hidden buttons, the information would only stay until the car was turned off. It's like changing the start up logo. Without the IDS, you get what was there from Ford, Merc or Lincoln. With it, you can change to whatever logo the head has stored.
The key here is that it was something in the developer's menu you were changing. It sounds like it is a backdoor used by the factory programming team to try stuff out on the fly without having to recompile, build, and reload the software for each change. Those tweaks were never meant to be kept and would require the IDS to make the changes permanent.
Thanks guys for the info. I gotta look this up to see if i can aquire these tools. Maybe then I'll be able change it to the way I like it.
Btw Akdoggie. Ive sent you an email and a PM.
Did you get them?
Did you get them?
