Radio Install 2008 - Pioneer Avic-D3x
Old Apr 15, 2008 | 09:19 AM
Ross_Gordon's Avatar
I am installing an Pioneer Avic-D3x I bought from Cruchfield in my 2008 Mustang GT.
I went by the wiring diagram they provided but I need to find a 12V accessory power lead that is wired to the ignition to turn the radio on which is different for the 2008 then the previous years.
The 12V switched power lead is not on the 2008 radio plug in.
If anyone has any ideas or has run into something similar I would be greatful for any help.
Thanks in advance.
Old Apr 15, 2008 | 04:36 PM
tom281's Avatar
There has to be a 12v switched lead running to the factory radio within the factory harness, or else the unit would only operate on full time battery power and therefore would work no matter if the key was on or not.... Unless they're using a < 12v signal to turn the factory unit on?
Old Apr 15, 2008 | 05:49 PM
I think it is just a 12V signal going to the factory radio.
I had crutchfield send me the 2005/2006 Ford wiring diagram for the radio plug in and where the 12V accessories is on it there is no wire going to it on the 2008.
Any other ideas are most welcome.
Old Apr 16, 2008 | 06:03 AM
2k5GTC's Avatar
You could always ask to see the wiring diagram at your dealership. Of course it depends on your relationship with them and how cooperative they are. I love my dealerships service department. They let me research wiring for all my vehicles when I am doing a mod.
Old Apr 16, 2008 | 08:38 AM
DarkFireGT's Avatar
Call crutchfield. They have a lot more detailed information than what they send you. But I can almost assure you that there's a 12v switched power coming in, unless they just changed it for 2008. With these types of harnesses, you basically just connect all the matching wires by color.
Old Apr 16, 2008 | 07:31 PM
withinavoid's Avatar
You can also try the AVIC411 forums.
Old Apr 16, 2008 | 08:07 PM
dmhines's Avatar
Thanks in advance.
So if you wire the AVIC harness to the Metra harness they supply and plug it into your factory wiring the AVIC does not power up? Before putting an Avic-D3 in my car last month I read every article out there about the Mustang Install process and never ever heard of somebody with a 2008 have this problem.
There only two gotchyas on a S197 Mustang are:
1) 5V regulator need to stop the sub-pop
2) 2007+ cars need an antenna adapter ...
Old Apr 18, 2008 | 06:57 AM
My Mustang is a Canadian model if that does make a difference.
The Ford wiring harnass does not have the accessories pin or wire to turn radio on are not in the harnass. So I used the number 6 fuse on the passenger side kick pannel, which is called accessory delay feed. Using an Add-a-Circut made by Littelfuse (www.littelfuse.com) which allowed me to have the radio come on with the accessories and still turn off when the the key is in the off position when you open the door.
Thanks everyone for your info and help.
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
