Questions about In-Dash DVD Unit
First I wanted to get some suggestions about which dvd unit to get. Then I was wondering if someone might have some insight into how you disable the e-brake function. I understand that you can have a "switched" ground to bypass this function. I am looking for a way to do this without having to wire a switch. Also, if the key is on and e-brake is up...it will play. What happens if you then turn the key to the off position leaving the e-brake up and then turn the key back to the on position? Does the unit still play being that the e-brake never changed positions? I'm asking this because if that is true then a normal ground sound allow for the same function as the e-brake. Or my understanding of what could be happening is off. Thanks for any help.
Originally Posted by sscobra
(Post 5582807)
