Kenwood DDX-7017 Install Complete
Old Feb 4, 2007 | 01:48 PM
WB2005GT's Avatar
I completed the install for my Kenwood DDX-7017, Kenwood Navigation Unit KNA-G510, Sirius Tuner and Rear View Camera. I used Hawgman's write-up http://forums.bradbarnett.net/showth...ht=skipper1000 and didn't have any problems. I hadn't planned on putting something like this in my car until the upgrade from Ford became available. When I saw the price for the Ford version along with the fact the the Ford DVD is not functional, I decided to go aftermarket. Since I am cheap I decided to get a factory refurbushed headunit and nav unit. I have about $1200 in the complete system and am very happy with it. Here are some pics.
The headunit
Attachment 18725
The nav unit (under the passenger seat)
Attachment 18726
The Nav unit has Garmin software and its really nice that it is a hard drive based system instead of DVD.
Attachment 18728
The rearview camera (I know I need to was my car)
Attachment 18727
One thing I like about it in addition to being able to put 4GB's worth of MP3's on a DVD you can also put some JPEG's on it and play a slide show or pause it on one picture and display it while you listen to the radio or sirius.
Attachment 18723
Attached Thumbnails Kenwood DDX-7017 Install Complete-1.jpg   Kenwood DDX-7017 Install Complete-3.jpg   Kenwood DDX-7017 Install Complete-4.jpg   Kenwood DDX-7017 Install Complete-5.jpg   Kenwood DDX-7017 Install Complete-6.jpg
Old Feb 4, 2007 | 03:20 PM
S197 V6's Avatar
I dont think the pics are showing up...or at least I dont see them
Old Feb 4, 2007 | 03:27 PM
WB2005GT's Avatar
I can see them when I open the thread.
Old Feb 4, 2007 | 04:34 PM
mikes rx's Avatar
That backup camera location is HOT!!!!
Old Feb 5, 2007 | 07:01 AM
WB2005GT's Avatar
Thanks, Can't take credit for the camera location it came from Hawgman's thread.
Old Feb 5, 2007 | 06:42 PM
TinPony2's Avatar
Is that the camera lens in the keyhole?????... u got pics of the inside??
Old Feb 5, 2007 | 07:14 PM
WB2005GT's Avatar
Yes, the camera is in the keyhole. I made a bracket out of some material from an old license plate. You can't see it because of the black plastic cover that covers that area on the underside of the deck lid. I'll try to get some pics tomorrow. Basically I took the cap off the camera, put the camera through the hole and put the cap back on tightening it against the rim of the hole. The bracket I made keeps everything secure, but it was really secure even without the bracket.
Old Feb 7, 2007 | 01:25 AM
P51Driver's Avatar
1SG,
Nice setup!! I'm partial to Kenwood myself so I'm curious if you used the same harness as Hawgman? Do all the speakers work? I have a Shaker 1000 and would like to keep the factory setup (amps).
Old Feb 7, 2007 | 07:33 AM
WB2005GT's Avatar
Thanks, yes I used the same harness that Hawgman used. All the speakers work and it seams like the Subs put out more base than stock. I did hook up the voltage regulator for the subs backward at first and got the pop but as soon as I re-connected it correctly the pop was gone. I had a Shaker 500 so only the white RCA plug from the small harness works for the front subs (I put a Y splitter on it to connect it to the HU) but I believe with the 1000 both work and will run front and rear subs.
Old Feb 10, 2007 | 10:02 PM
hawgman's Avatar
Congrats SG1. Nice setup. Wow, that backup camera is a killer idea . Also, much diggin the Garmin. I am considering swapping my NAV4100 for it. Actually, more than considering, just haven't gotten off my lazy butt and done it. I think the hold up is knowing ( or at least assuming ) that I am going to have to swap out the harness that runs from the head unit to the GPS unit. If it would work on the same harness as the NAV4100 I probably would have already bought it. Yea...i'm getting lazy.
Hey, what faceplate kit did you use?
Old Feb 10, 2007 | 10:28 PM
WB2005GT's Avatar
Thanks, I wouldn't have even tried it without your write up. I used the faceplate kit you recommend in your post.
Old Feb 11, 2007 | 05:51 AM
another 06gt's Avatar
the camare is awsome location
Old Feb 11, 2007 | 09:15 AM
blackstang06's Avatar
Do you have a link to Hawgman's thread? Also, when I went to Best Buy, they said I would need an amp bypass($150) if I wanted a new headunit for my shaker 500. Is this true?
Can I get a new headunit for my shaker 500 that still uses the stock subs?
Old Feb 11, 2007 | 09:20 AM
WB2005GT's Avatar
Here is the link.
Whoever told you that at Best Buy dones't know what they are talking about. My subs work fine and I had a Shaker 500. You just have to get the right harness and use a voltage regulator so the subs won't make a pop when they come on. The regulator costs $1.70 at radio shack.
Link to Harness (notice the RCA plugs for the Subs)
http://www.installer-data.com/item/d...php?it=70-5521
Do a google search and you may be able to find it cheaper.
Old Feb 11, 2007 | 09:30 AM
The RCAs on that adapter plug into the new headunit right? The stock headunit has 3 harness plugs, but the new headunit only uses two of them. What does the 3rd plug do?
Here is the link.
Old Feb 11, 2007 | 09:58 AM
WB2005GT's Avatar
Not sure what the third stock one is for but it is not used. The harness with the RCA plugs has the wires to power the subs and yes the rcas plug to the sub out on the new HU. On the Shaker 500, only the white RCA plug works, so I got a Y splitter and plugged the white one to the 2 from the HU. I believe with the Shaker 1000 the white RCA is for the front subs and the red one is for the rear (I could be wrong).
Old Feb 11, 2007 | 10:04 AM
hawgman's Avatar
OK kewl. For some reason it looked different. Looked like it was textured and the one I had was smooth. Probably just the picture.
Anyway, again, nice setup man. Congrats. Next step is to get rid of those crappy speakers and amps and put something worth listening to in there
Attached Thumbnails Kenwood DDX-7017 Install Complete-picture-013.jpg   Kenwood DDX-7017 Install Complete-picture-021.jpg
Old Feb 11, 2007 | 10:05 AM
hawgman's Avatar
Oh yea, congrats on being the new guy to have to answer all the stereo questions. Glad to pass that torch along
Old Feb 12, 2007 | 07:21 PM
Infinity's Avatar
You could do like me- show up every month or so to answer all the PM's, then bail out.
Old Feb 12, 2007 | 07:41 PM
WB2005GT's Avatar
I got 2 today, but that's ok, I have got a lot of help from the forum and I don't mind giving some back.
