Installing Nav Radio in 2008 Mustang
I recently replaced the Shaker 500 radio with a new Nav radio in my '08 GT. The installation went well, thanks to the thread on installing in an '05 model, with the same difficulty in handling the connectors on the bottom of the panel. I installed the antenna on top of the heater box, since it was fairly far forward and under the windshield, had no metal above it, was able to place the antenna facing straight up, and was easily reached by dropping the glovebox door. The radio has performed well. However, the radio does not fit evenly with the trim panel. It sticks out a bit at the top relative to the bottom. I've pulled everything again and looked at all the radio mounting tabs and they are snug against the panel, so I can't understand why this is this way. Any thoughts? Is there some other adjustment somewhere to even these up?
=Vic=
=Vic=
Radio with antenna was bought new off eBay, prices range from $550-$750. New radios need to be programmed for your options (Aux input, type vehicle, etc.) as it communicates with the car for speed sensing, instrument lighting level, etc. That runs $90-$150. That's it! On mine, everything works perfectly. Radio sounds good, the multiple MP3 player is awesome, and the GPS tracks dead-on and calculates rerouting extremely fast. That said, it does not appear any more capable than VZNavigator on my cell phone and actually a bit more "insecure" in that it often, in my very rural area, announces it can no longer provide turn-by-turn directions as the map data is incomplete, so it highlights the route in yellow and stays silent. Those "yellow" routes are totally correct, in my experience, but you have to keep an eye on the map as you drive when that is on. VZNavigator keeps directing right to the destination.
=Vic=
OK, I took the dash apart again and now see what the issue is. The radio has a post on the back with a rubber cover (as did the Shaker) and that rests on top of a brace bar behind the radio. As it is, it prevents the radio from rocking back so no amount of washers on the bottom screws would help. I found this post screws on to a smaller post coming out of the radio, so I removed the outer layer of rubber and thicker post and it helps. Still not perfect, but a little better. I also checked the side brackets and there is no adjustment in those, so this seems to be just the way it is.
=Vic=
=Vic=
As as aside, while I had the ruber cover off that post, I seemed to be receiving fewer satellites than I do now that it is back on. Perhaps that is a coincidence, but thought I'd mention it anyway.
=Vic=
If you have been watching the other thread on nav installation, others that have installed the nav system are getting a speed error. Are you getting this error?
If I do a self-diagnostic routine I get something called an ECU configuration error. I suspect that relates to a Satellite radio function which seems to have been enabled on mine, even though I don't have it. The SAT button comes up on the Media screen, but if you press it there is an SDARS configuration failure note on the top line. Perhaps that means I could add the module later without having to reprogram the radio? Anyway, it is certainly not a problem as I just don't select it.
=Vic=
Well, this turns out to not be such a mystery, and I only post this to prevent others from making the same mistake as I did. Turns out that rubber covered post on the back of the radio is supposed to fit in the middle of that cross brace behind the dash. If it sits on top, the top will stick out like mine did. If under that brace, the bottom will sitck out. If you're careful, reaching up under and behind the radio as you guide it in, you can fit that post right in the hole it is supposed to go in in the middle of the brace. When in correctly the radio fits perfectly even with the dash.
=Vic=
=Vic=
Thanks for the info.
Is that a stock Nav radio?? From Ford or aftermarket?? Been away from the radio subject for awhile and this is all new to me.
Last I saw my 2005 radio was NOT compaitble with anything.
Really want ipod & satellite radio integrated into my Shaker 500....??
=Vic=
=Vic=
=Vic=
Want to ask what the NAV unit is called and wondering if it would fit in a 08 Bullitt
Yes I know this is from 2008 but lots of good info here and the other navigation thread. So I took a risk guy had one the pioneer ford version on ebay for best offer out of 2008 Expedition had the chrome *****. I offered 50 and he accepted he had upgraded. I bought a $10 gps antenna on amazon pink plug. It is magnetic I stuck it above the metal bar above the glove box. As soon as I plugged the nav system in it started to load got the ford screen and it loaded the dvd map that was in it 12p. So far everything works because its out of an Expedition it has rear dvd which the mustang doesn't have and i don't need. One hint when pulling the center bezel the wires on the bottom the connectors are easy to see and unhook if you do it from behind through the foot wells. So far Im happy with it I think it sounds better than my shaker 500. I have not checked out the speed volume thing yet, thought that was a convertible thing. I may update maps to 13p those are from 2012 or 2015. 12p i think is 2011 or 2012
VGMStudios (10/2/22)
Tms Mustang Member ------ The Customizer!
Humm Maybe I should put mine up for sale. I got it to work with my 07 mustang and it has SYNC.
Glad you got yours to work.
2014 mustang radio
Can someone please help me in putting in a pioneer to my 2014 mustang and the aftermarket wiring harness doesent have white or grey wires to wire in my front speakers can someone help
I’m installing a double sun with metra dash kit all I need to know is how do I get my front speakers wired in, can I connect them to the green and purple or will that mess up the radio
thanks.
thanks.
The Analog Admin!
Received 2,992 Likes
thanks.
thanks.
VGMStudios (11/17/22)
Thing is I dont know the 2014 all to well. Im mostly 05-09 but I can try to help but Ill need pictures.
The one WHITE wire I can find is LEFT Speaker according to this:
https://iihs.net/fsm/?d=711&f=130%20...Navigation.pdf
There is no GREY only wire.
05stangkc (11/17/22)
