Help- installed a new head unit
I searched.....
Installed a new head unit and purchased a wiring harness for the install. The kit only has one plug and everything works fine except the door subs. I went back to the shop where I bought the harness and they said they don't have a harness yet that interfaces with the stock Shaker 500 amps for the door subs.
Surely someone makes a wiring harness that will interface and allow the door subs to work- anyone know who makes this kit and maybe have a part number??
Thanks,
tom281
Thanks,
tom281
I ran into the same problem with my installer. He was a retard. What you needed in the first place was the Metra 70-5521 - the harness for the stock speakers plus the harness for the subs. But you already have the main harness, so what you need is the Metra 70-5522 - just the sub harness.
They're hard to find separately - I just bought a whole new harness from Crutchfield, since at the time it was the only place I could find one. I found one here:
http://oem-auto-accessory.com/70_5522_ford...003_and_up.html
Can't vouch for these people, though. They charge less for the two harnesses than they do for the sub harness!
Also, with the subharness, you're going to need to put a 12V to 5V transistor on the power leads to keep 'em from popping the amps, like this guy:
http://www.dennisjudd.com/archives/000947.html
Mr. Sparkle
Sep 11, 2015 02:57 PM
