Facotry dimmer wire?
Old Mar 3, 2008 | 02:14 PM
Factory dimmer wire?
Bought a Crutchfield deck and harness and installed a few months ago. The auto dimmer feature on deck is not working, and I think I heard somewhere that the harness that you get for the install is great, but this wire is off. Does anyone know which wire the illumination wire from the deck should be connected to on facotry side of harness. I guess I could do process of elimination, but I thought somebody might have run into this before?
Old Mar 3, 2008 | 06:13 PM
sook's Avatar
Its just the way the car is. The dimmer wire in the center stack is controlled by the SJB and doesn't put out a strong enough signal for aftermarket stereos to pick up. This is how it was explained to me. the crutchfield harness did not dim out either my Kenwood KDC-790 or my Pioneer Avic D3. Most have run wires to the headlight switch or maybe one of the LEDs that turn on when you hit the headlights.
If you can find a better way though trial and error, it would make alot of peoples lives a bit easier.
Old Mar 3, 2008 | 06:49 PM
davesiar's Avatar
There is a write up in another forum about this also. The guy pulled the headlight switch out and tapped into the yellow/blue wire on the back of the headlight switch. http://forums.bradbarnett.net/showthread.php?t=75672 . Hope this helps.
Old Mar 5, 2008 | 05:00 PM
Torch_Vert's Avatar
The blue/yellow wire on the hazard flasher switch at the top of the center stack works and is easier to get to.
Old Mar 5, 2008 | 07:28 PM
Thank you so much that will save me a lot of time, I appreciate your help.
Old Mar 5, 2008 | 07:55 PM
05fordgt's Avatar
+1 on that. Its where I tapped into for my D3. Easier than the headlight switch.
Old Mar 5, 2008 | 08:10 PM
You see that's what makes the internet so freakin awesome, you ask and you shall receive, in numbers. Thanks guys.
Old Mar 6, 2008 | 08:24 AM
sook's Avatar
wish i knew about that wire a couple months ago. but it seems like a perfect wire to tap to dim out a wideband between the vents
Old Mar 7, 2008 | 02:19 PM
flamin ponyexpress's Avatar
It's the same wire yellow/blue,just a easier place to get to it.
May 3, 2026 05:42 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
mx5jhb
Sep 30, 2015 04:44 PM
Sep 23, 2015 03:21 PM
