EasyGuard Keyless Entry system.
Old Mar 15, 2021 | 01:08 AM
Derek Daughetee's Avatar
Help!! EasyGuard Keyless Entry system.
Any help or feedback Will be greatly appreciated.
So eight months ago I purchased one of those easy guard keyless entry systems from Amazon originally I was going to install it in my 2018 Jeep Wrangler.
However after purchasing my Mustang and having it be my daily driver I thought it would be more convenient to install it in the mustang. I haven’t even attempted to start this project, as I’m trying two collect as much information as I can make sure I have all the right hardware.
The easy card system there is basically nothing to it. Here is the wiring diagram.
Easy guard PKE Push button, Remote start and keyless entry
when I was doing my research to install this in my jeep I realize you have to bypass the temperature so I also purchased IDatalink
This is not the correct wiring diagram for my Mustang. (For the jeep)
from my understanding the Datalink bypass module basically takes over and controls everything moving forward. Like bypassing the Chip in the key.
I have been searching for a wiring diagram or the ignition with no luck. The only thing I found was the green wire is the starter wire
if anybody has any experience with this please speak up. I guess my biggest question that I need to figure out is where all the wires from the data link connects at. I’m going to try and start this project this weekend so I will Trey to make it very detailed with lots of pictures
Old Mar 18, 2021 | 01:51 PM
VGMStudios's Avatar
Tms Mustang Member ------ The Customizer!
Wire diagrams can be found here:
https://iihs.net/fsm/?d=40&f=Starting%20System.pdf
About the Ignition:
https://iihs.net/fsm/?d=7&f=Ignition%20Systems.pdf&p=1
Dunno if this will help or not:
https://iihs.net/fsm/?d=414&f=Passiv...ransceiver.pdf
Old Mar 18, 2021 | 06:33 PM
Originally Posted by VGMStudios
It does a little bit. Thanks man 👍👍 I’m gonna attempt the install this weekend
Old May 9, 2023 | 09:06 PM
Jaywicked's Avatar
were you able to make this work ? please get back at me with info if possible
Old Jun 30, 2023 | 02:57 AM
Dhillon's Avatar
I'm trying to tackle this as well to make my s197 push start. Any idea on how to do it?
Old Jun 30, 2023 | 02:58 AM
Dhillon's Avatar
Were you able to get it working with your mustang?
coolnchic
Apr 7, 2016 06:01 PM
pity7700
1994-2004 V-8
Feb 2, 2013 07:41 PM
EastCoast07GtCs
05-09 Interior and Audio Mods
Feb 21, 2008 06:04 PM
Al Blue4.6l
May 16, 2006 09:27 PM
