Driver's side kick plate removal
Old Feb 7, 2008 | 11:58 AM
1FAFP90's Avatar
Okay, I've tried prying with screwdrivers, slotted tools, etc, and I can't get the black round pin to budge more than 1/8 inch. Everyone else says it's easy to remove. What am I doing wrong? Thanks.
Old Feb 7, 2008 | 12:02 PM
Mustang05's Avatar
IDK??? All you do is pull up on it..... about a 3 second job
Old Feb 7, 2008 | 12:32 PM
1FAFP90's Avatar
Pull up on it - do you mean the black pin or the whole kick panel? Do I even have to remove the black round pin at all?
No joke - I've been pulling / prying on that round pin for a total of over 15 minutes. I take a break, do something else, come back to it, and it won't budge more than that 1/8 inch. Doggone it.
Old Feb 7, 2008 | 01:05 PM
karman's Avatar
If you have it (the pin) 1/8 inch, get under it again and pull harder.
If it breaks go to Pep Boys and get a new one.
Old Feb 7, 2008 | 01:10 PM
1FAFP90's Avatar
FIANLLY! I ended up reaching my hand behind the kick panel where the pin is located, and pulled using the backside of the kick panel.
Thanks for the encouragement! I guess I'm not s strong as I used to be.
Old Feb 8, 2008 | 03:22 PM
Emu Hunter's Avatar
I think they make a $10 gizmo designed to pull those things without destroying them. I widdled a homemade one out of a putty spatchula. Seems to work. It just looks like a flat pry bar, with the slot in the middle sized to those pins.
poldrv
Aug 18, 2015 06:42 AM
glo106
Aug 11, 2015 08:29 AM
TrueBlue302
Jul 23, 2015 06:13 AM
Vader99
Jul 19, 2015 08:19 PM
