Dashboard scratch... repair?
Old Sep 28, 2007 | 09:58 AM
bigray327's Avatar
I was installing my new stereo the other day and - like an idiot - I scratched the dashboard. It looks awful.
A friend of mine that used to professionally install stereos told me they used to take a torch (gulp!) and lightly toast the area to turn it black. Has anyone tried this? Does anyone know of a better or less risky way to make this not look like crap? I can't see spending probably $200 on a new one when there's probably an easy way to make it look good.
Thanks!
Old Sep 28, 2007 | 10:37 AM
WaltM's Avatar
Exterior polish. I've seen guys use it on interior plastic with "fair" results. Try a real fine cut, like swirl remover and do the entire glove box door. If you dont, you'll see a shine where you applied it.
You should get most of it out, but you'll probably end up seeing a little bit of scratch when your finished. If it fails, It's new glove box door time...
Old Sep 28, 2007 | 11:33 AM
bigray327's Avatar
Cool, thanks, I'll try that. FYI, it's not the glovebox door, it's the fixed piece above that.
Old Sep 28, 2007 | 11:53 AM
WaltM's Avatar
If your using a swirl remover, you may have to repeat the process a couple of times to get the "rash" out, so be patient.
Old Sep 28, 2007 | 02:46 PM
citizen arcane's Avatar
It looks like that is a plastic piece. I use Novus Fine Scratch Remover #2 on all plastics (gauge faces etc.) w/ excellent results. This stuff can usually be found locally at Fine Boat Shops. Highly recommended!
Old Sep 28, 2007 | 04:53 PM
krnpimpsta's Avatar
I scuffed up my E-brake removing/replacing that center console piece. It has a bunch of little scratches that are about 0.5mm deep. Do you think that scratch remover work on this?
Old Sep 28, 2007 | 05:57 PM
It's possible. As stated, I'm able to get fine scratches out of plastic bezels for gauges and the plastics pieces on my 96 GT. Give 'er a go! It'll only set ya back 6 bucks or so. If you're like me, it's just another bottle in my detailing box(es.)
Old Sep 28, 2007 | 07:19 PM
GRAYPNY's Avatar
You think your's is scratched, check this out!
Old Sep 30, 2007 | 07:31 AM
WaltM's Avatar
OMG! Wahappened?
Old Sep 30, 2007 | 08:54 AM
GRAYPNY's Avatar
Installed gauges- I was trying to be funny
Old Sep 30, 2007 | 11:18 AM
pantera72's Avatar
Don't quit your day job.
Old Oct 2, 2007 | 08:16 AM
CHDS PNY's Avatar
wow...same thing happened to me about a year ago
i will have to try that scratch fix
oh and BTW...that piece isnt a replaceable piece...well unless you want the entire dash replaced
Old Oct 4, 2007 | 04:07 PM
bigray327's Avatar
I tried the scratch remover. It took two tries, but it worked well. Thanks all.
Old Oct 5, 2007 | 07:29 AM
CHDS PNY's Avatar
can we get some after pics?
did you go in circles?
Old Oct 9, 2007 | 01:43 PM
cop on my back's Avatar
Where did you get that dash plaque? Ebay? If so, I personally know that guy that makes/sells them. He gave me one at a car show this year. I don't know how he got all the information on my car, I suspect through a mutual friend somehow. They are a pretty nice item, I put mine on the rad support.
Old May 20, 2010 | 11:52 AM
Bullitt8585's Avatar
Are you saying that the piece in this picture is not replaceable? What else needs to be replaced with it?
Old May 20, 2010 | 08:18 PM
jim010's Avatar
That piece unfortunatley is part of the 'whole' dash. You can replace it - if you buy used for a minimum of a few hundred dollars (I replaced mine when I changed the interior colour from gray to black).
To get scratches out, I scubbed the hell out of the area with Vim. That worked ok. Then I used a Norwex magic eraser. That worked really well for taking out scratches. I then wiped the area with baby wipes (all I had) to clean the area. Worked well.
robjh22
Dec 14, 2015 08:41 AM
GTPETE
Oct 12, 2015 02:20 PM
Fred_Garvin
Sep 17, 2015 04:10 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
GMAYS
Sep 10, 2015 06:19 AM
