center console power outlet options
Old Nov 14, 2009 | 11:43 AM
06Ponypkg's Avatar
Is there an easy way to set the power outlet in the center console to only be active with the ingnition on?
I have a Sirius radio that I have plugged in there, and want it to power on/off with the key.
any help is appreciated.
TIA
Old Nov 14, 2009 | 06:45 PM
Richocet83's Avatar
You'll have to cut the current power source wire and splice it to a line that is ignition controlled. Beyond that... Sorry. Someone else should be able to give you more detail... There are a lot of diy guys here.
Old Nov 14, 2009 | 08:19 PM
06Ponypkg's Avatar
I was afraid that would be the case...it's never simple is it? I've had other vehicles where you could just move a fuse to make an outlet active with the ingnition. I was hoping that would be the case here...oh well...time to get out the wire strippers I guess.
Old Nov 16, 2009 | 07:25 AM
Richocet83's Avatar
I've seen a number of people using "add a circuit" fuse box plugs to power additional accessories in their cars... If you can find an empty fuse opening that is powered while car is on only you can run a line from that to your power outlet. Just give yourself enough cord to cut the original connection and connect the new.
Old Nov 16, 2009 | 10:28 AM
NickDC123's Avatar
Tap the PRND321 for pos and the power port for neg. That's what I did for OEM ambient lights and they work great and turn off when key removed.
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
AMWill
Jul 20, 2015 08:40 AM
