Cabin Air Filter replacement (with pics)
I finally painted my hood a month or so ago, took some pics of the drain/filter while I had access...never got a flood inside, but it was plugged almost solid...40k miles/5 years old next month- I'd say 2 years would be about right for cleaning/filter change. someone mentioned 'pulling the grommet out', I pulled it to clean it out, but put it back in- it has a flapper that keeps road spray from blowing back in, I dunno if the filter might get wetter without it...in any event, be sure to clean the drain every couple years or risk flooding your interior/smart junction box...
Good news when I checked my air filter today; the filter was dry and relatively clean and the chamber was clean and dry despite no rubber grommet (I had taken it out). Road spray did not blow up from the engine compartment/wheels....and it is really rainy in Vancouver in the winter so there was lots of opportunity.
Here are pics from the FIRST CHANGE in MAY where the filter was soaked and water coming into the passenger foot well.
Standing water in the compartment
Junk in the duck-bill grommet I removed you can see it in the top right area of the chamber in the first pic
Hope this helps someone out there. If the filter's chamber drain clogs, it fills up and then flows into the cabin filter and then into the fan area and will drip from behind your glove box. You would find it after washing the car or a really heavy rain. Ford is hit and miss on helping out with this.
Cheers
Cheers
I took off my plastic cowl cover to have a look at the grommet and the entire cavity because I am getting water on the passenger floor but mine is all clear, no sign of any leaves or debris. Water was coming from something up/under the dash and also out from under the bottom (carpet) edge of the kick panel where the electrical junction box is
nice write up, much appreciated Bill.
aside swapping the aftermarket bling wheels mine came with to torque thrust 17's she has never been to a dealer
\/ this is why the first investment for my ride was a cover. \/
When I had my 05 Gt the retards told me I didn't have one oh really so I walked up to the parts counter bought one and walked outside if front of all of them changed it and brought the dirty one inside and asked if they'd please dispose of it ! This write up will just impower the more of us to get er done ! thank-you guys !
thanks for the write up!! just want to check as I was directed to this post and this is for 05+ mustangs, and mine is a 2004 model Mustang, is the air filter going to be accessible in the same manner the 05+ air filters are? im refering to the cabin air filters, I am going to be checking mine soon and replacing it (most likely its never been done) and don't want to tear up my new to me ride with out knowing the proper location/prodecure.
Thanks!
Thanks!
Thanks!
Thanks!
sarnold58
Jun 9, 2019 02:22 PM
Rodsmustang
Sep 16, 2015 04:02 PM
